F5 Turbo is posted
F5 Turbo is posted
Old 22nd July 2012, 05:48 AM   #581
lhquam is offline lhquam  United States
Default Roots of the F5 Turbo
I just ran across this. Perhaps it has been mentioned before in this thread, but I have not seen it.
Bob Cordell Interview: BJT vs. MOSFET
Nelson says:
BTW, there is a pair of diodes - I also used a trick that I got from
Barney Oliver of using power diodes to shunt across emitter
resistance so as to limit the maximum voltage at high current.
It made the job easier for my (admittedly crude) bias circuit.
Old 22nd July 2012, 07:00 PM   #582
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 Turbo is posted
Similar trick. Actually I didn't get it from Barney Oliver, but later discovered
that he had done it before me.
Old 23rd July 2012, 05:46 AM   #583
In the F5 Turbo, would you say that the goal of the diodes was to increase transconductance by decreasing the effective source resistance, or to increase the output voltage swing at high currents, or something else?
Old 24th August 2012, 02:50 AM   #584
Pointed is offline Pointed  Viet Nam
Pointed's Avatar
In user point of view, may I consider this diode trick as a kind of power saving solution for class A schematic
We don't need to set highly idling current (Id) but we still can get large, intact output power out signal (without clipping at negative half cycle)
Not too hoot, not bad at all. Sorry, if may I wrong!
Old 24th August 2012, 09:18 AM   #585
AudioSan is offline AudioSan  Norway
no. not at all.
the bias is just as high.
Old 1st March 2013, 12:43 AM   #586
joesch1999 is offline joesch1999
24v secondarys for f5 turbo right
Old 1st March 2013, 01:31 AM   #587
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Depends. 50W yes. 100W, you need 32V secondary.
...Shape the sound , Man!
Old 1st March 2013, 01:37 AM   #588
labjr is offline labjr  United States
Would 800 VA be enough for 100 watts?
Old 1st March 2013, 02:11 AM   #589
buzzforb's Avatar
For 100W V3, you are gonna be dissipating about 250W per channel. I would think 800 per channel or monoblock is more ideal.
Old 1st March 2013, 02:19 AM   #590
when are there going to be boards available? I need v3 and f5c
F5 Turbo is postedHide this!Advertise here!
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 06:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 04:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 12:52 PM
Zca ....turbo east electronics Solid State 9 10th April 2010 05:49 PM
Copyright ©1999-2017 diyAudio
