F5 Turbo is posted - Page 58 - diyAudio
Old 21st June 2012, 06:04 AM   #571
lhquam is offline lhquam  United States
Originally Posted by buzzforb View Post
Very nice. How do the measured numbers compare to simulated ones?
Overall there is decent agreement between the simulation and the actual circuit, but I am not sure I have enough experience with this circuit to answer the question definitively. I have some doubts about the accuracy of the MOSFET and MUR diode models. There are some issues with the LTSpice results I haven't figured out. Perhaps there are LTSpice convergence parameters that need tweaks.
One thing that both the simulation and the actual circuit show is that reasonably high bias (> 1A) is needed to get THD below .005%. Both show that the Turbo diodes greatly reduce THD at high power levels versus the non-Turbo at the same bias.
I have not yet done any listening tests of the version with diodes. I have been listening for more than a month to a nearly identical balanced F5 pair without the diodes. It sounds very good.
Old 28th June 2012, 05:10 AM   #572
Since we are squeezed to limit bias and source resistance, has anyone considered 4 diodes in series-parallel? That way the people with enough heat sink can push the bias up higher and still keep the diodes from conducting at idle. There would be about 0.6 volts more drop at high power (depending on temp and current), but still have more power and less distortion than no diodes at high power. My main drawback to that is the extra cost of double the diodes and heat sinks.
Old 12th July 2012, 12:14 PM   #573
Has anyone tried these boards from Jim’s Audio? Personally I’d rather buy from the store here than ebay (the guy must be making some money out of this all be it a small amount), but these seem to be the only turbo boards available.
Mosfet pure class A amplifier thick PCB turbo V2 stereo !! | eBay
Old 12th July 2012, 03:15 PM   #574
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
Guys, silly question follows:
Is the f5 a constant current source amp (like what is described in Pass'es article "current source amplifiers and sensitive/full range drivers)?
I'm that guy who finds ways *not* to do things..
Old 12th July 2012, 03:22 PM   #575
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
No, a current source amp is volt in and current out.
F5 is a voltage amp, volt in and volt out.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 12th July 2012, 03:29 PM   #576
Nikitas's Avatar
Thanks jacco.
Any examples of ccs amps that are available in this forum?
BA1 for example, is it a ccs?
Old 12th July 2012, 03:48 PM   #577
No, the BA1 front end is voltage in and voltage out, output stage is push-pull.
For a current source amp, the output stage can not be symmetrical (top & bottom look the same)
F1 and F2 are current source amps, constant current source on top, bottom is transconductance stage (volt in, current out).
Current difference between top and bottom goes to the loudspeaker, so volt in and current out.
Old 12th July 2012, 04:00 PM   #578
Nikitas's Avatar
dank u!
Old 12th July 2012, 04:12 PM   #579
nrg2009 is offline nrg2009  United States
very helpful, thanks Jacco.
Old 12th July 2012, 04:13 PM   #580
Parakalo, calispera.
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 06:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 04:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 12:52 PM
Zca ....turbo east electronics Solid State 9 10th April 2010 05:49 PM
Copyright ©1999-2017 diyAudio
