Old 30th May 2012, 11:04 PM   #501
buzzforb's Avatar
Already have one!
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 31st May 2012, 02:23 AM   #502
lhquam is offline lhquam  United States
Originally Posted by EUVL View Post
You are misquoting me I am afraid.
My proposed alternative (in post #42) is not based on reducing the source resistor (only).
The key to my proposal is using MOSFETs with much higher Yfs (e.g. 2SK3497).
That, combined with a reduction in Rsource will give the same current gain as a 2SK1530 plus a diode.
See :
F5 Turbo is posted
And I do not consider 0R33 for Rsource to be low. The F5X uses 0R22 since day one.
Nor have I ever experienced any bias stability at steady state.
Yes, the bias is a bit lower when cold. But once it has warmed up, it stays there.
Assuming of course your heat sinks are properly sized.
And I am still not a believer of the diode.
Patrick
I was indeed "under-quoting" you.
My enthusiasm for the Turbo has declined to agnostic after more LTspice simulations. I do not trust the device models. Until I actually perform live tests I will defer judgement on the Turbo.
I do agree with you (EUVL) about the balanced F5 at 16V with low source resistors. I am built one as reported in: Balanced F5 in a Small Footprint. It uses .25 ohm source resistors and achieves very low THD up to 50 watts at bias currents as low as 1 amp.
Old 31st May 2012, 02:44 AM   #503
Banned
I am going to the pub
Old 31st May 2012, 02:53 AM   #504
Banned
Just wondering whether you guys will believe in real world measurements.
We can quickly end all of this, if I do the measurements.
I generally prefer to use my ears though.
Old 31st May 2012, 06:35 AM   #505
Banned
Amazing what you find when you have a look.
Old 31st May 2012, 08:12 AM   #506
buzzforb's Avatar
Funny thing is, you don thave to hav eon eor the other. Melon head has shown the improvement it makes. If you like Rs that is low, like .22R, then run the bias @ 2A an dstill use the diodes. You get the distortion improvement from higher bias, you are using a lower Rs, and the diode is still there for a little extra grunt.
Old 31st May 2012, 08:40 AM   #507
Banned
Yeah no worries.
You can have any source resistance you want (with or without the diodes).
The higher the source resistance the greater the bias will jump when the diode completely turns on.
The lower the source resistor the lower the bias will jump when the diode completely turns on.
Old 31st May 2012, 09:49 AM   #508
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
KLUNK!-!KNULK
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 31st May 2012, 10:08 AM   #509
buzzforb's Avatar
NO ZM!
Hump Hump!
the bunny hump - YouTube
Old 31st May 2012, 10:15 AM   #510
Zen Mod's Avatar
poor bunny ........
I can clearly see he's having post-coital depression
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 03:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 11:52 AM
Zca ....turbo sakis Solid State 9 10th April 2010 04:49 PM
Copyright ©1999-2013 diyAudio
