F5 Turbo is posted - Page 48 - diyAudio
Old 25th May 2012, 03:20 PM   #471
Banned
I have matched jfet models
Mine was biased to 1.3A in both cases
Old 28th May 2012, 02:30 PM   #472
Banned
Something just occurred to me about the circuit.
I think it is capable of even better performance, just need to wait till tomorrow to confirm it.
Old 28th May 2012, 02:58 PM   #473
lhquam is offline lhquam  United States
Before I saw your non-Turbo/Turbo THD plots and did some simulations, I was not convinced about the Turbo. EUVL has proposed an alternative based on reducing the source resistors to near zero, which helps, but increases the problem of bias current vs. temperature.
I am now a believer in the Turbo.
Old 28th May 2012, 03:05 PM   #474
Banned
Hehehehehehe
If my hunch is right, I will be very happy.
Nelson is very sly.
I feel dumb again (as usual) for not thinking of this immediately.
Very basic stuff. Not rocket science.
Bloody brilliant though
Old 30th May 2012, 04:16 PM   #475
Banned
Hehehehehehe
Nelson is very sly.
My hunch was right. Although the improvement is only subtly better than the original diode results posted earlier.
Old 30th May 2012, 04:27 PM   #476
EUVL is offline EUVL  Europe
You are misquoting me I am afraid.
My proposed alternative (in post #42) is not based on reducing the source resistor (only).
The key to my proposal is using MOSFETs with much higher Yfs (e.g. 2SK3497).
That, combined with a reduction in Rsource will give the same current gain as a 2SK1530 plus a diode.
See :
F5 Turbo is posted
And I do not consider 0R33 for Rsource to be low. The F5X uses 0R22 since day one.
Nor have I ever experienced any bias stability at steady state.
Yes, the bias is a bit lower when cold. But once it has warmed up, it stays there.
Assuming of course your heat sinks are properly sized.
And I am still not a believer of the diode.
Patrick
xen-audio.com
Old 30th May 2012, 04:30 PM   #477
Banned
Are you talking to me Patrick?
Old 30th May 2012, 04:35 PM   #478
I was referring to post #473.
Patrick
xen-audio.com
Old 30th May 2012, 04:43 PM   #479
Banned
Patrick it is very quick and easy to wire a diode into your circuit.
Probably take all of 30 minutes to try it and if you don't like the results take it out.
Just try it.
Old 30th May 2012, 04:53 PM   #480
AndrewT is online now AndrewT  Scotland
Simply adding in a parallel diode to the source resistor is not advised.
I have asked a few times what is the set up procedure to give the diode version of the F5 a real chance to perform well. To date I seem to be the only one answering myself.
I still have to write up partIII.
regards Andrew T.
Sent from my desktop computer using a keyboard
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 06:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 04:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 12:52 PM
Zca ....turbo east electronics Solid State 9 10th April 2010 05:49 PM
Copyright ©1999-2017 diyAudio
