Old 26th April 2012, 07:15 PM   #361
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by AudioSan View Post
cascode referance voltage = rail voltage/(R25+R27)xR27
so for 50V rails it will be:
50/(10K+4.75K)x4.75K= 16.1V
for 32Vrails:
32/(10K+4.75K)x4.75K= 10.3V
Audiosan,
Proved these work in real work measurements.
Thank you.
Biasing seems a little trickier than standard F5.
I am going to do some more testing of values for R5,R6. I think I will go to 2.2K from 1K.
I find as the voltage climbs, my pots have limited and timid offset adjustability. I removed the thermistors to see if it helps, and it does not. Makes it easier to set bias for me.
Attached Pic 1 -Cascoded version running 48V, Jfets at ~16v
PIC a version 2 one running strait out.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 26th April 2012, 07:22 PM   #362
good to hear
what is your bias goal? and how many outputs?
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 26th April 2012, 07:28 PM   #363
Tea-Bag's Avatar
good to hear
Well, for testing 1,2,3 and 4 I am trying to build several variations to cover functionality of the board and part behavior.
But does this affect Bias? Both version 2 and 3 schematic show same R values here for R5,R6 - P1,2.
Old 26th April 2012, 07:34 PM   #364
the bias will affect the adjustmet of the pots. so for high bias,
it migth be good to change the value of the resistors.
one must just try and see what works best
Vivaldi8 speakers
Old 19th May 2012, 04:02 AM   #365
Tea Bag are selling any power supply boards?
Old 21st May 2012, 10:45 AM   #366
Tea-Bag's Avatar
wrong thread for my boards - but not currently. I am considering.
I would recommend the one from chip amps.com under the Aleph PS section. If you look around you can get some decent size bug caps on it, plenty of space for 5 .47R resistors and a place for 2.2K 5W bleeder resistors. And six big caps, 4 TO-220 type diodes can go here, and each can have a 2" tall heatsink. I will try to post a pic of one, if nobody has one quickly. It's <10.00usd. That's hard to beat!
Old 21st May 2012, 12:37 PM   #367
here is 3 without the diode's one with 6x10.000uF 80V
2 with 6x12.000uF 35V
they all have 2.2Kohm bleeders and 4.7uF bypass caps. CRC resistors is 4x0.47ohm on one. and 5x1ohm on the 2 others.
Vivaldi8 speakers
Old 21st May 2012, 02:21 PM   #368
6L6 is offline 6L6  United States
6L6's Avatar
Chipamp.com Aleph PSU board shown with Antek 400VA shielded transformer -
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 21st May 2012, 03:41 PM   #369
Banned
Everyone is hopelessly addicted to the F5 amp.
What have you done Nelson?
You have created a conundrum
Old 21st May 2012, 09:59 PM   #370
he released a decic
Vivaldi8 speakers
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 03:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 11:52 AM
Zca ....turbo sakis Solid State 9 10th April 2010 04:49 PM
Copyright ©1999-2013 diyAudio
