F5 Turbo is posted
F5 Turbo is posted
Old 11th February 2012, 02:33 AM   #131
labjr is online now labjr  United States
Originally Posted by Nelson Pass View Post
For these purposes they are fine. Actually, in our testing they fit all our
applications.
Thanks,
It would seem they're drop-in replacements for the Toshiba JFETS. I was just wondering if they will sound as good the Toshiba since the Toshiba are obsolete and becoming rare. I wonder why Toshiba themselves didn't replace them with something better?
Old 11th February 2012, 03:23 AM   #132
EUVL is offline EUVL  Europe
> In any case, if you want this kind of current, you will have some mild transitions unless you want to run 20 amps or more of bias.
I don't mind the transition that much, I do care that it is too close to bias (normal listening).
If I were you I would keep the bias voltage across the R_source at say 0.3V.
That I know the diode won't kick in till I almost leave Class A anyhow.
But why not try 3497/681 ?
Patrick
xen-audio.com
Old 11th February 2012, 04:46 AM   #133
NYCOne is offline NYCOne  United States
Default Balanced Rail Voltage Choices - more Class A
NP -
When I built my Balanced Cascoded F5, I chose the lowest rail voltages that had a flat transconductance plateau for the MOSFETs (2SK1530 and 2SJ201 at 16V). I did this so I could crank up the current and have more power in Class A at a given wattage for each output device.
I noticed you were recommending higher rail voltages and paralleling devices for more power, but wouldn't more current help with Class A?
Old 11th February 2012, 05:05 AM   #134
thomasfw is offline thomasfw  Hong Kong
I'm sorry !
Am I right, FQA12P20 was a Discontinue Product ?
Thanks !
Old 11th February 2012, 11:29 AM   #135
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Not big enough a market anymore.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 11th February 2012, 11:34 AM   #136
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
Absolutely. Fairchild doesn't even list it anymore. No stock at Mouser, no stock at Digikey.
Best regards: Holger
www.holgerbarske.com
Old 11th February 2012, 11:48 AM   #137
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 Turbo is posted
as always - it looks as Papa have world's quantity on his shelves
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th February 2012, 11:49 AM   #138
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 Turbo is posted
You could substitute FQP12P20 which is a TO-220 device -- the transconductance is a tiny bit lower and the device has a higher thermal impedance...
Old 11th February 2012, 12:07 PM   #139
Originally Posted by jackinnj View Post
Lateral MOSFETs have half the input capacitance of the vertical ones but less than a quarter of the steady state current carrying capacity.
Ah, but even at 1S to 1.5S, the power diode trick would save a couple of volts.
With oldy 600mW JFET cans at the entrance, 4 laterals in parallel would be near equivalent.
Old 11th February 2012, 12:23 PM   #140
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Will this trick work on f4 like buffer?
F5 Turbo is postedHide this!Advertise here!
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 03:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 11:52 AM
Zca ....turbo east electronics Solid State 9 10th April 2010 04:49 PM
