oneplustwo F5 build thread - Page 3 - diyAudio
Old 16th February 2012, 01:37 AM   #21
I am cought-up in same situation, got the original boards and the updated techdiy parts.
Here's the "un-official" missing parts list: 2-100K resistors
4- .47 3w resistors
4-47 resistors
4- 2.2K resistors
4-1K resistors
4-150 resistors
4-10K resistors
If you have boards with a status LED, you can use "un-used" 4.7K resistors
from the kit.
I ordered the missing ones staying with Dale's CMF series.
Please, correct me if i did a mistake somwhere guys!...
Old 16th February 2012, 11:07 AM   #22
One+2,
if you are using a CRC filter for your power supply then the umbilical comes to your aid to assist with attenuating the unwanted frequencies that get past the rectifiers.
Keep the transformer and rectifier and first stage smoothing capacitance in a very tight low loop area configuration. That is the first part of your rCRC giving you r = lead and secondary resistance. C = first bank of capacitors.
The next stage is effectively located in the power amplifier box.
As you may already know, an LC filter performs better than an RC filter, when looking at attenuation of the unwanted versus the voltage stability at the output.
Think of your umbilical as a combined L+R where L = very low value and R = very low value.
Without adding any discrete inductor, nor adding any discrete resistor, the the umbilical impedance provides the L+R in the second stage filter.
This results in a rC(L+R)C cascaded filter. This performs very well if the impedances at either end of the umbilical are kept low.
The attenuation of the unwanteds improves as the L & R of the umbilical increases.
And just to help you along, the inherent core to core capacitance of the umbilical also aids attenuation of VHF trying to impinge on an exposed umbilical.
Use that to your advantage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th February 2012, 03:04 PM   #23
oneplustwo's Avatar
Interesting. Thanks for the detailed response. If I may ask a follow up question, is there any special grounding scheme I need to follow as a result? (for context, I plan on having a 3 foot long 4 conductor umbilical with 14ga wires terminated with speak on connectors.)
Old 16th February 2012, 03:17 PM   #24
Start with this.
understanding star grounding
Pay special attention to Mains Safety.
Then move on to
Audio Component Grounding and Interconnection - diyAudio
There are other threads discussing similar psus.
regards Andrew T.
Old 16th February 2012, 04:52 PM   #25
6L6 is offline 6L6  United States
6L6's Avatar
Read the links Andrew speaks about. Good stuff.
If you are going to have an outboard PSU you are going to need at least 2 more capacitors...
Put the transformer, bridges, and a pair of caps (Say 10,000uf or thereabouts and 35v or more, remember, they are going to get the brunt of the ripple) in the outboard case. Your red PSU board will be in the case with the amp circuit boards.
Old 16th February 2012, 07:42 PM   #26
oneplustwo's Avatar
Wow... this is complicated. I read through the links but only understood a small fraction. I'm a mechanical engineer... not smart enough to be an EE!
Would it be any simpler if I kept the rectifiers in the amp case and had AC go through the umbilical?
Maybe I'll just stick with the one box solution...
Old 16th February 2012, 08:19 PM   #27
6L6's Avatar
It's not that big a problem, and that article does make it seem much more complicated than it really is.
If you do choose to do the 2-chassis approach, you should make the umbilical DC, so the Transformer, bridges and 1st set of caps are in the same box.
Old 18th February 2012, 12:32 AM   #28
lhquam is offline lhquam  United States
Do you have any estimate of the thermal rating C/W/3" of those heatsinks. I am using Heatsink USA E007 heatsinks which are somewhat larger: 10"x7"x2.5" 24 fins, which has a rating of .7 C/W/3".
[QUOTE=oneplustwo;2901510]No pictures yet... but here's where I'm sourcing parts from so far:
Heat Sinks:
Got the ones that Antek uses for this enclosure. $25 each shipped with the trafo to help minimize costs (also ordered a B1 trafo and small heatsink.)
Old 18th February 2012, 01:40 AM   #29
oneplustwo's Avatar
According to them, they are rated at 0.6 C/W/inch.
Also, it's 160 sq in per lineal inch with 37 fins.
Old 18th February 2012, 01:57 AM   #30
nrg2009 is offline nrg2009  United States
Great looking build.
How to build the F5 6L6 Pass Labs 1133 23rd January 2014 05:32 PM
FS: Parts for F5 build Milkduds Swap Meet 2 5th July 2011 04:33 PM
ZM's (not) F5 thread Zen Mod The Lounge 87 26th March 2011 02:40 PM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 10:58 PM
Copyright 1999-2017 diyAudio
