#212 |
1.21 Gigawatts?!
#213 |
Put it in a steel box.
#214 |
1.21 Gigawatts?!
#215 |
The Earth ground probably isn't it, but do try a couple of configurations, you will probably make it quieter.
Look at the signal grounding, start by removing one of the ground wires from the PSU board and attaching both ground wires to the same point on the psu (I.E., both signal grounds to one side.) There was a guy who recently had a similar problem with the red board psu, I will try to dig it up. |
#216 |
1.21 Gigawatts?!
Aha! I think I forgot to tie the signal ground to the PSU board in the first place!
![]() Oops. I will try that tonight and see what happens. |
#217 |
NTC please
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#218 |
1.21 Gigawatts?!
Sorry, what does NTC mean?
EDIT: NTC is the CL-60 thermistor? In which case, I think I'm good since the PSU PCB is already populated with that. Last edited by oneplustwo; 9th April 2012 at 07:03 PM. |
#219 |
Yes, the NTC is the CL-60 ground-breaker. Not the 2 in the PSU being used as the inrush suppressors.
Attach the signal grounds to the ground-breaker, and at the same spot. Hopefully that's the problem. |
#220 |
Negative Themperature Coefficent
Also on bias thermistors 4.7K |
| How to build the F5 | 6L6 | Pass Labs | 1088 | 25th April 2013 07:44 PM |
| FS: Parts for F5 build | Jimmy D. | Swap Meet | 2 | 5th July 2011 04:33 PM |
| ZM's (not) F5 thread | Zen Mod | The Lounge | 87 | 26th March 2011 02:40 PM |
| Next suggested build after F5 | anilva | Pass Labs | 36 | 3rd December 2010 04:11 AM |
| F5 Build Instructions | 1108 | Pass Labs | 4 | 12th May 2009 10:58 PM |
