My Threshold SL10 Mk 1 was finally taken out of the cupboard to fit new caps
and replace the J505 constant current diodes and 2N172 Mosfets as the pins were showing signs of corrosion. This was an ideal time to trace out the circuit which is presented here as there are notable differences to the SL 10 circuits previously presented in DiyAudio. The MK1 designation is my own concoction to identify the different circuits in the SL10 stable. Bill Sadler |
#2 |
thank you
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3 |
What is the gain of the MC-pre section?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#4 | ||
pps - William -nice circuit, - isn't there a 22R with another 22R switched in parallel on the input to the MC input?-Mal |
#5 |
According to the SL10 brochure, the MM section has 33db gain at 1khz.
The MC section adds another 20db gain. ---Gary Last edited by GaryB; 6th February 2012 at 04:36 AM. |
#6 |
I think the 20dBs are referred to the line stage....?
50dB overall gain from RIAA ti line out is somewhat meagre as it is...
#7 | |
The MC gain depends which MC cartridge you are using. How much gain is possible? Here's my example: My MC cartridge's output is only 0.2 mV, so the input impedance selected on the preliminary phono gain (MC) stage is the lowest setting on the SL10: 1 through 15 ohms (highest gain possible). The MM RIAA phono gain stage adds +33dB. To feed the high level stage (+20 dB gain) with 1 volt requires +74dB total gain, not quite a volt in my setup, so the SL10's MC section gain is about +40dB. ![]() -Mal |
#8 |
Malatron you are correct, I have the original operating manual which specifies the gain of the MM stage as 33 dBs and a gain of 20 for the line stage, by the way this is over the top, way too much gain, I have added so much resistance in series with the Volume control. This has affected the sound so I am going to have to find another way of killing gain, I can use the MM stage as a MC stage with just impedance adjustments. I am of the opinion that the circuit I published is all washed out and not very clear, I have redone the circuit to improve the resolution but must find a way of replacing the circuit published.
William |
#9 |
gain (line stage ) is directly dependable of ratio of 18K2/1K5
increase 1K5 to ,say, 3K3
#10 |
Zen Mod Thanks for that, I have been playing with
both the RIAA stage and the Line Stage in LTSpice and have various options. Leave the RIAA stage as is for the moment (I have redesigned the RIAA feedback components) and then use a 10K resistor in place of the 1K5 in the feedback leg of the Line Stage mounted proud of the PCB to enable different resistor values to be easily added in parallel to avoid repeatably messing with the PCB. A 5K resistor (10K || 10K) will then give 8 dB gain with the gain switch open and 12 dB gain with the gain switch closed. I also want to avoid fiddling with the PCB too much as it doesn't take kindly to removing components with thru the hole soldering. ps I have tried this, much better and I am in the ball park of were I want to be. As confucius says "it is not the work stupid but the decisions decisions" |
| Restoring a Threshold SL10 | GaryB | Pass Labs | 6 | 13th March 2013 10:18 AM |
| threshold sl10 | intense-tavda | Pass Labs | 110 | 2nd July 2011 09:10 PM |
| threshold sl10 | donadi.tv | Pass Labs | 1 | 15th February 2008 04:25 PM |
| Threshold sl10 fs | intense-tavda | Swap Meet | 3 | 23rd December 2006 11:22 AM |
