Old 22nd September 2003, 04:39 PM   #1
JayV is offline JayV  Sweden
Smile Aleph 2 parts
I just got six 2*38V, 1500VA Transformers For you in sweden i can reccomend microtraf!! I Paid 5000kr (540€) for these, including shipping!
I'm going to build six Aleph2's and i look for psu caps now, will four Evox-Rifa PEH-200, 22000 uF/63V be enough per amp? It get a bit expensive if i use four 47000 uF instead :/
Party on Wayne!
Old 22nd September 2003, 06:29 PM   #2
loovet is offline loovet  Sweden
Hi JayV,
Your transformers look just great.
I’m also planning to build Aleph 2. As a supplier of transformer I’ve had microtraf on my mind. And it makes me really happy that you can recommend them.
I haven’t given the caps any thought yet. I’m a little bit more worried about finding appropriate heat sinks, at least at a reasonable prise. Have you bought your heatsinks yet? And if so, from where did you by them?
BR
loovet
Old 22nd September 2003, 06:41 PM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Here is my current setup for aleph 2's as i'm still in the building faze..
http://24.71.244.254/Photo/view_albu...umName=album17
Old 22nd September 2003, 07:02 PM   #4
I have read somewhere that microtraf make transformators for Copland.
Nope havent found any affordable heatsinks yet, but i'm thinking about cutting out "heatsinks" in foam with a hobby cnc mill, dip them in plaster (gips?) and then cast them myself.. Only about 150€ in materials cost! And then i get them exactly as i like... Also i would make really cool 3d frontplates
Party on Wayne!
Old 22nd September 2003, 07:07 PM   #5
UrSv is offline UrSv  Sweden
UrSv's Avatar
JayV, you could easily have saved a bit on the transformers as 1500 VA is plenty if it is one per channel. An Aleph 2 draws only 300 W.
The factory Aleph 2 uses 4 pieces of 22.000 uF so that should be OK. A bit more won't hurt but don't give it too much IMHO. Try to get PEH169 instead of PEH200. You would need 24 of them. Price for 47.000 uF instead is not even close to double at Elfa. Check that. BC does nice things. The 22.000 uF cost for 24 pieces would be about EUR 600. Call MJS Electronics and buy the lot of 400 pieces of 4.700 uF/50V ELNA caps for about EUR 250 is an option. Use some and sell the rest and caps are for free...
Lots of sinks around. Try Siefert or the Fischers at Schuro.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 22nd September 2003, 07:11 PM   #6
Banned
i'm using 6 x 37,ooo mf caps
111000.mf per rail per amplifier. : O)
Old 22nd September 2003, 07:27 PM   #7
I like it BIG! hehe, acutally i don't think it was so expensive! I mailed toroid about an equal transformator and i belive it was 3 times as expensive!
I have read that PEH169 is better for audio, but i can't find any 63V on their page.. Perhaps i should mail them and ask!
I wonder what the temperature will be in my listening room No problem in the winter tough as we often have -25C (or even -30C) hehe
Party on Wayne!
Old 22nd September 2003, 11:38 PM   #8
Loris is offline Loris  Italy
Hi JayV, could you explain us something more about that "plaster" you mentioned?
Seems Interesting, at least in different applications.
Old 23rd September 2003, 02:41 AM   #9
38VAC secondaries will give you rails somewhere in the vicinity of 50VDC (I think stock was 45V, but I don't have a schematic handy to check). Heat dissipation will rise accordingly, so watch your heat sinking. You'll also get a bit more wattage out of the circuit.
Offhand, I can't think of any parts that will need to be changed to accomodate the higher rails.
With a 1500VA transformer you could run two channels and still have power to spare. Considering that you've got six, you could go for twelve channels total...were you thinking surround, by any chance?
Or you could run the bias up. Yes, they sound better that way. I've got mine set so that I can vary the bias over a wide range. When the bias is low they start sounding thin, anemic, high-fi in the wrong sense of the word. Increased bias fills in the sound so that the ribs don't show. I typically run mine about 10% over stock.
Grey
Old 23rd September 2003, 07:07 AM   #10
I'm going to triamp linkwitz phoenix or somthing like that but with a digital filter/dsp (Behringer DCX2496).
Hmm i belived the "real life" formula was about 1.2 as in 38*1.2 = 45.6V nevermind, never wrong with more power ;D I'll just cast som really big heatsinks...
For casting info just search for "lost foam casting" on google or something...
Party on Wayne!
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
WTB: Aleph parts monarodan Swap Meet 0 25th October 2006 11:04 AM
FS Aleph Parts bacworth Swap Meet 10 8th July 2005 10:31 PM
Aleph 4 parts tomchaoda Pass Labs 3 17th October 2003 01:52 AM
Aleph 5 -- Parts billy Pass Labs 2 9th January 2003 11:28 AM
Page generated in 0.11131 seconds (80.19% PHP - 19.81% MySQL) with 11 queries
