several Aleph's in one big case
Old 3rd February 2012, 11:36 AM   #1
aaronboumans is offline aaronboumans  Netherlands
aaronboumans's Avatar
Default several Aleph's in one big case
I am building a new 8-channel amp. 4 aleph 60's and 4 alep30's in one big case
It is an extention from my stereo-system to 5.1 (all active).
My question is;
As all 8 unbalaced inputs are connected to one active filter, so sharing the signalground, should I connect all powersupply ground (from all 8 Aleph's) to eachother? All 8 amps are in one case, should I consider it to be one amp or as 8 amps in one case? What's the best internal wiring? All seperate or all together?
I hate carryable audio-equipment!
Old 3rd February 2012, 01:37 PM   #2
with picture
so maybe will react faster
notice the cd for size reference
see build here;
http://www.zelfbouwaudio.nl/forum/vi...hp?f=7&t=11329
Last edited by aaronboumans; 3rd February 2012 at 01:42 PM. Reason: forgot something
Old 3rd February 2012, 01:48 PM   #3
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by aaronboumans View Post
....should I connect all powersupply ground (from all 8 Aleph's) to eachother?...
let each stereo PSU have it's gnd connected to chassis via 10-20R NTC
that , with proper layout of power buses and input cables , will give you hum free operation.
hopefully
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th February 2012, 02:48 PM   #4
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
wow, that's a lot of heat to dissipate in one case...
my Aleph 2 mono blocks look about as big, when put side by side
good luck finishing it up!
Old 4th February 2012, 04:56 PM   #5
zen mod; so all eight grounds seperately with 8 NTC's to chassis.
Can you explain why? thanks
@moe29
I will measure the heatsink for proper comparison
Old 4th February 2012, 06:49 PM   #6
Zen Mod's Avatar
you said :
so - fact is that each PSU must be connected to safety gnd , same as case ;
if you connect those PSUs ( read - PSU grounds) ditto to safety gnd , you'll have gnd loop between inputs and PSU side gnds
when you connect those PSU gnds via 10-20R NTCs , that resistance is usually enough to avoid gnd loops
read Pass papers - there you'll find pretty clear and often humorous explanation for all important audio things
Old 4th February 2012, 07:28 PM   #7
like this?
http://www.dz3w.com/uploadfile/2010/...5101057521.gif
in the right lower corner, the thermistor?
From circuit and chassis ground to the NTC to the AC outlet ground.
Old 4th February 2012, 07:32 PM   #8
Zen Mod's Avatar
sort of , but not exactly
look in F5 pdf , for instance
there are two NTC's - one in-line with mains (as soft start) , and another one between gnd and chasiis , which is directly on safety gnd
Old 4th February 2012, 08:16 PM   #9
and I should do this will amps in the one case. All 8 gnd throught 8 ntcs to chassis/acgnd
Ok
thanks Zen Mod
Old 6th February 2012, 09:56 AM   #10
I measured the heatsink;
its 96x50x33 cm(24,4x19,7x13 inch)
several Aleph's in one big caseHide this!Advertise here!
Big Amp Case lgreen Swap Meet 0 17th November 2011 07:35 PM
chipamp case design (warning big pic inside) neutron7 Chip Amps 22 29th November 2005 08:57 AM
aleph-x versus other aleph's anders.a Pass Labs 2 19th May 2005 07:20 PM
Aleph's Heatsink ruangrit Pass Labs 4 1st February 2004 04:29 PM
Aleph's and what speaker cable??? bacworth Pass Labs 6 6th January 2003 02:21 PM
Copyright ©1999-2017 diyAudio
