My question is for use with single ended, when shorting the (-) input, I could use a higher quality film cap for the + input and - output? Leave the - in and + out with cheap electroyltic caps? Ideally same logic applies to P1.7 ? or would it be better to short the + input so you get non-inverting output? Thanks |
#2 |
whatever you do , both input signal caps are always in signal line/path
any input , even if grounded , is still in signal path
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Please clarify.
At which point(connections) do the + and - input share the signal path, (even if one of them is grounded)? |
#4 |
I said always
that pretty much covers every point/connection ![]() it's pretty much clear that signal is flowing through both caps when both inputs are used ; but - if you observe that signal side is virtual gnd for (each) input , then is logical that cap is important in both cases - when input is virtually and actually grounded
| Aleph P1.7 | KatieandDad | Pass Labs | 21 | 2nd December 2011 07:17 PM |
| integrated amplifier with aleph p1.7 and mini aleph | vivanco | Pass Labs | 10 | 20th April 2011 04:48 PM |
| Original Aleph P1.7 in/out caps | bbakota2000 | Pass Labs | 3 | 28th November 2004 08:45 AM |
| aleph p1.7 | Kongen | Pass Labs | 3 | 27th November 2003 04:28 PM |
| Aleph P1 | Tony D. | Pass Labs | 1 | 6th April 2001 09:03 PM |
| Page generated in 0.07071 seconds (70.55% PHP - 29.45% MySQL) with 10 queries |
