Banned
I thought I would peek my head through the door of the Pass Labs area.
I avoid this area due to shear information overload. I have a transformer salvaged from a Bryston 3B, I was going to restore it but recently changed my mind. Actually the Bryston has 2 transformers, one I have already started to modify for something else. Now on the bottom of the Bryston amp it says 960VA, however on the transformers themselves read 250VA. They are center-tapped, I can easily divide them into separate rails. Is it possible that I have a ~500VA transformer ie: 250VA per rail? That would add up to what it states on the bottom. So if you can save me days of reading and point me in the right direction. What model of Pass goes with 50volt rails? Is my 250VA enough or do I actually have 500VA? Thanks for your time. |
#2 |
250VA each is too small for Class A use. You might like to consider Class A/B or one of the newer Class D amps.
There are a few but my Aleph 4 uses 48-0-48 at over 3A per channel. It needs at least 500VA per channel. Last edited by KatieandDad; 30th January 2012 at 05:35 PM. |
#3 |
Zen version 1,2,3,4 or Zen Light
Zen V9 or Firstwatt F3 PLH DeLite L'amp (oops Sorry Micheal) That would be using your + and - rails as positive for 2 ch. Really dosen't sound like you have enough otherwise? Just off the top of my head...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss Last edited by flg; 30th January 2012 at 05:38 PM. |
#4 |
Banned
Looks' like I have some reading to do. Not a panic, just trying to find a new project for when my current one is done. You got to keep one in the oven.
Thanks |
| What can I build with +/- 60v rails? | 6L6 | Pass Labs | 17 | 2nd February 2012 01:27 PM |
| Benefits/Drawbacks of Dual rails vs Single Rails | buzzforb | Pass Labs | 2 | 25th May 2011 01:06 PM |
| WTB: BGN 4,7uf 50v, 10uf 50v & 22uf 16v | Pocoyo | Swap Meet | 1 | 16th September 2010 02:09 AM |
| Triaxial wire build for power supply rails | jneutron | Parts | 16 | 28th April 2006 06:08 PM |
| build power supply for35vdc rails | doggy | Power Supplies | 17 | 10th January 2006 04:56 AM |
| Page generated in 0.06840 seconds (72.69% PHP - 27.31% MySQL) with 10 queries |
