Old 29th January 2012, 05:29 PM   #1
Talking Best isolator for output devices on an F5 ?
Need your help once more.
I will need isolators for the outputs and for the rectifiers diodes.
Rectifier diodes will be MUR3060.
Tried to find myself but i admit that the choice is overwhelming!...
I heard of one that don't need thermal grease, i'd like to use those,
good enough?.
I want something that performs well .
Thanks,
Pierre
Old 29th January 2012, 07:27 PM   #2
labjr is offline labjr  United States
Kerafol Keratherm Red 86/83 Isolators TO-247 $1 /ea - in stock
Old 31st January 2012, 11:04 PM   #3
Well, thanks Labjr ! This is what i was looking for.
Old 3rd February 2012, 02:57 AM   #4
Tried to contact member Zhoufang about the Keratherm from Kerafol,
no answer.
Is there another source in North America?.
Old 3rd February 2012, 05:04 AM   #5
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
when communicating with Zhou , you need little patience ;
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 3rd February 2012, 07:33 AM   #6
Bksabath's Avatar
If you are in a rush I got a litle bit to spare
I can cut strips of 21 mm 375 mm long
This way it fits TO247 TO220 with litle waste, this stuff is expensive.
Old 3rd February 2012, 07:12 PM   #7
Great idea!, as a matter of fact, i would prefer it that way !.
I will not need a mounting hole as i will use the "plate with 2 screw" type
of mounting.
PM sent, thanks!!!
Old 4th February 2012, 12:15 AM   #8
Bksabath's Avatar
of mounting.
PM sent, thanks!!!
PM sent back
I am using M4 bolts as the more the pressure the beter the Kerafoll work.
Loads of pictures on MY F5 tread.
Old 14th February 2012, 09:00 AM   #9
Bksabath's Avatar
Cutting guide for 21 mm strip
This stuff is expensive so to minimise waste 21mm wide fits all.
Old 15th February 2012, 04:37 AM   #10
Thanks Bksabath!. Received the strips, i was thinking of using a strip
of Kerafol under and OVER the outputs, wanting to use an aluminum bar
with 2 screws to hold down the devices.
Sounds like a good idea?.
Analog Devices Usb isolator for Medical coldcut Digital Source 2 21st November 2011 03:38 PM
Output Devices ! cloud Pass Labs 11 10th November 2008 11:37 PM
Output devices? Mr Evil Class D 42 12th January 2005 02:18 PM
question on output devices! sardonx Solid State 3 2nd December 2003 10:22 PM
parelleling output devices hacknet Solid State 8 18th December 2002 11:22 PM
Page generated in 0.09219 seconds (86.63% PHP - 13.37% MySQL) with 11 queries
