Without seeing an impedance curve it is not possible to say,
Do note that the sensitivity assumes a voltage amp, and in the case of all the Klipsh speakers i've seen measures for are 3-5 dB optimistic on the spec sheet.
dave
counting on that always (-4db) , when Klipsch is in question
even PWK had special sort of db
Well, I'm not afraid about low power amp as now I'm using a 6w one, but more on the notes I read into F2 manual regarding the matching between drivers, crossovers and amplifier. As Mr. Pass said, if no one has faced the same situation yet, maybe I sholud try...
- F2J Speakers match
