Old 25th January 2012, 08:30 PM   #1
Redwingnine's Avatar
Default Converting a Threshold S300 to SA/3?
I would like to be able to convert a Threshold S300 to a SA3. From looking at the manuals, it looks like the amps are very similar.
Was looking for input as to if this is possibe? The speakers I'm using seem to work fine with a SA/3 I tried out on them (loves the high current).
Thanks for any help.
Old 26th January 2012, 02:56 AM   #2
seng is offline seng  Hong Kong
I just convert my SA3 to S300 , if you want convert S300 to SA3, it only need to changed the supply voltage from +- 62 V to +- 34V (the original transformer had this wiring) and adjust the VR5K to the proper bias for the out put transistors (totat 2.2A for each channel).
Old 26th January 2012, 06:10 AM   #3
analog_sa's Avatar
Don't think all S300 transformers have this option though.
Old 26th January 2012, 09:59 PM   #4
Thanks much for the feedback. My S300s are optical bias types, so the trasformers should support this.
Curious as to why you converted to S300? Do you need the extra voltage for your speakers? I have found that the Class A output to sound better overall with my speakers.
Old 27th January 2012, 07:11 AM   #5
Yes, class A is better, so I had Threshold SA3 & T100, but SA3 can converted to S300 to drive my Dynaudio Speakers.
Besides,please replaced the 4pcs rail fuse to 8A after you converted to SA3.
Old 5th February 2012, 12:32 PM   #6
Completed the conversion of the first of two S300 to SA/3. Also changed out the emitter resistors.
The bias was a bit tricky, but it did stay at the new setting after a couple of tries.
I continue to be amazed at just how different (and better) tha amp sounds runnig in class A. It seems that most speakers are quite happy with 50 watts in class A. The speakers seem to have more bass heft running class A, and the reduced distortion is audible, no question.
This is one my favorite amps from Nelson. It just sounds like music.
Old 5th February 2012, 12:48 PM   #7
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just be sure that that Graetz cooling plate on top of caps isn't too hot
everything above hand temp is too much for caps
relocate Graetz on back plate , if needed
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 5th February 2012, 03:48 PM   #8
The chassis, plate, and internel layout of the S300 and SA/3 iis identical, so no worries there.
Class A is definately the way to go if the speakes support it.
Old 5th February 2012, 11:19 PM   #9
PKI is offline PKI  United States
and can S200 be converted in to class A amp SA/something? Thanks.
Old 6th February 2012, 02:36 AM   #10
The short answer is, no, do not think so. The trnsformer in S200 is only 400VA, and I am not sure what other rails are on it.
You could check with Jon S. ay Vintage Amp Repair to ask.
Upgrade and restore Threshold S300 aspiens Pass Labs 5 4th October 2011 08:25 AM
Threshold s300 Amp Power on Thud nellson Pass Labs 16 30th August 2010 05:57 PM
Threshold SA/ and SA/e series monoblocks gigi.vassallo Pass Labs 0 6th January 2010 07:07 PM
Threshold S300 offset issues FootFungus Pass Labs 5 15th December 2009 12:58 AM
Threshold S300 output transistors help jewilson Pass Labs 12 24th June 2002 07:44 AM
Page generated in 0.11576 seconds (79.52% PHP - 20.48% MySQL) with 11 queries
