#11 |
That's ok just curious. Seen one locally. Thanks.
#12 | |
Mine sadly does not have the extra windings. Might as well look for a replacement transformer. As the original PS caps are far from great sounding, the reduction in voltage also presents the opportunity to go for lower voltage/higher capacitance/better quality caps should you decide to make the change permanent. If the bridge cannot take it, might as well go for some better sounding rectification too. Btw, replacing the NFB decoupling caps from the original polycarbonates to Musicaps worked out extremely well. |
#13 | |
I replaced the original PS caps with a pair of 68000 uf at 75VDC, along with solen NFB de-coupling caps. Yes, it does help indeed. |
| Upgrade and restore Threshold S300 | aspiens | Pass Labs | 5 | 4th October 2011 08:25 AM |
| Threshold s300 Amp Power on Thud | nellson | Pass Labs | 16 | 30th August 2010 05:57 PM |
| Threshold SA/ and SA/e series monoblocks | gigi.vassallo | Pass Labs | 0 | 6th January 2010 07:07 PM |
| Threshold S300 offset issues | FootFungus | Pass Labs | 5 | 15th December 2009 12:58 AM |
| Threshold S300 output transistors help | jewilson | Pass Labs | 12 | 24th June 2002 07:44 AM |
| Page generated in 0.07618 seconds (69.90% PHP - 30.10% MySQL) with 11 queries |
