Wattage of Pass F5
Wattage of Pass F5
Old 25th January 2012, 03:28 PM   #81
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Russellc View Post
contemplating
Lower rail voltage means lower power, but also means a higher bias current at the same dissipation level.
Then there's the option of playing with the AC bias factor, alter it to 0.25 (down from 0.5) and peak output current will be four times the bias level.
The Aleph 2 is biased at 0.5A per output device, makes 3 Amps total quiescent current.
Read the service manual : Peak output is 10 Amps, makes 200W continuous in 4 Ohm theoretically.
For less easy loudspeakers a better choice.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 25th January 2012, 06:03 PM   #82
R.I.P.
the set AC current gain factor of the dynamic bias thingus.
For the standard factor of 0.5,
Jacco, could you explain this for me?
regards Andrew T.
Old 25th January 2012, 06:25 PM   #83
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by KatieandDad View Post
Sorry but you mis-understood my post.
My speakers are INEFFICIENT - they wouldn't suit the F5.
I stated that the F5 is best suited to someone with EFFICIENT speakers.
96dB/W is "Efficient" relatively speaking, be careful how the sensistivity has been measured though. Some manufacturers are blinding us with misleading figures.
Me tinks you mean Less sensitive , very different from efficiency.....
Old 25th January 2012, 06:33 PM   #84
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Yes the B&Ws needs loads of power,
Old 25th January 2012, 06:47 PM   #85
Sin Bin
Ahhh that they do, most speakers do as a matter of fact, always sounding more "alive" when fed some power...
High sensitivity 2 way speakers sound unbalanced to me, well everyone i have ever heard. To get high sensitivity and a good balance require a large multi driver speaker 3-4 way at the very least.
regards,
Old 25th January 2012, 06:59 PM   #86
Russellc is offline Russellc  United States
Wattage of Pass F5
regards,
Wow, tastes do vary...I find the 3 and 4 ways with poorer balance than the 2 ways!
Russellc
Old 25th January 2012, 07:00 PM   #87
Wattage of Pass F5
OK, sounds like I have picked the correct amp for my purposes, thanks for the insight.
Russellc
Old 25th January 2012, 07:16 PM   #88
Originally Posted by AndrewT View Post
explain this
What is there to say ?
The Alephs are not classic single-ended amps with fixed bias, but have a steady-state bias (no signal) plus dynamic bias (with signal at input/output) of the current source.
(as to be expected from the master of sliding bias arrangements in Threshold amps)
My candid camera short version : the connection between output and biasing arrangement fools the bias transistor in believing that the voltage drop across the output source resistor goes down, in effect : more quiescent current (of the current source).
For the long version, read Zen Part II.
Personally, i do not view the Aleph amps as True Class A, but semi Class A.
Similar to Krell's sustained bias plateau, Threshold's sliding stuff.
Without the dynamic bias thingy, it would become a standard SE amp, max output current is quiescent current => AC current gain factor = 1
If the AC gain setting is altered to something near 0, the amp starts to resemble push-pull (high bias Class AB )
See bottom half of the output stage. What happens there when the positive output current goes beyond the static bias current level ?
So :
0 = PP Class AB
1 = SE Class A
Therefore 0.5 = 1/2 Class A (aka semi)
(so, each Aleph amp can be custom tailored to the loudspeaker system in question. Rotten LSP needs bigger supercharger)
Old 25th January 2012, 07:42 PM   #89
Sin Bin
Russellc
I can believe that ... Poorly made/designed speakers, nothing to do with them being multi-way. Done right , no single speaker or 2 way will come close...
Much easier to get a 2 way correct.....................
Old 25th January 2012, 08:01 PM   #90
ramallo is offline ramallo  Europe
ramallo's Avatar
Wattage of Pass F5
IMMO multiway = multi point sources = multi-problems.
I heard and adjusted (and made) dozens of multiway systems, and my feelings is the best one is the one way (But is very difficult to achive a good performance, my Quad ESL can, but the drawback are a low headroom), the second best is two way, the third best is three way.........
But is my taste
Happiness is a warm soldering iron
Wattage of Pass F5Hide this!Advertise here!
Pass F5 Help Needed vdi_nenna Pass Labs 34 12th July 2015 12:40 PM
Pass F4, F5 and Motif amps joda Swap Meet 2 24th December 2010 10:16 AM
Pass F5 clone parts for sale wirewiggler Swap Meet 2 9th April 2009 03:01 AM
PDF about F5 amplifier of Sensei PASS NihonJR06 Pass Labs 1 25th May 2008 05:27 PM
