Wattage of Pass F5 - Page 13 - diyAudio
Old 26th January 2012, 02:37 PM   #121
KatieandDad's Avatar
If you go to the http://www.firstwatt.com/prod.html site you can read the articles on the more recent Aleph J's, Aleph X and the F series amps amongst the others.
Old 26th January 2012, 02:38 PM   #122
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by pdhanwada View Post
50 W class A.
Define 50W Class A.
(normal 50W Class A is an amp that is able to deliver 3.5A peak output current without cross-over distortion due to part of the output stage closing shop)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 26th January 2012, 03:01 PM   #123
a.wayne is offline a.wayne  United States
Sin Bin
I get your point. I feel Alpeh4 is little too much for my place. It will turn out be a furnace generating about 600 to 800 watts of heat continously.
My place has 9 months of summer to 3 months of winter. Is there any other design which will get me 50 W class A.
Pandu
Do the CViller cascode dual output version, this version can deliver 50watts /ch ....
Old 26th January 2012, 03:10 PM   #124
I had a look at the DIY-Audio store on the Cascoded F5 but the schematic images seem corrupted ?
Old 26th January 2012, 04:50 PM   #125
bobodioulasso's Avatar
http://www.diyaudio.com/forums/blogs...version-2.html
Old 26th January 2012, 04:56 PM   #126
That certainly clears matters up. On The DIY-AUDIO schematic everything is BLACK, the colours indicate the options available.
Old 26th January 2012, 06:51 PM   #127
Originally Posted by jacco vermeulen View Post
What is there to say ?
Thanks for the explanation. Now I understand the reference to the 0.5 factor.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th March 2012, 05:34 PM   #128
Just searched for "F5 power" to check my calcs, and came across this; some good info.
I would just like to see if some of my thoughts/calculations are right. This is what I calculate:
Regarding the power of an F5, I calculate about 100W into 8ohms. This is assuming 40Vp-p output (a best-guess with +/- 25v rails). This gives P=Vrms^2/R=((20*sqrt(2))^2)/8=20^2*(2/8)=400/4=100w (if that notation makes any sense!). You can bias as you wish - or really has heat permits. The manual says bias to 25w, but I'm seeing this Class A power as "arbitrary" - is that right?
EDIT: At 100W, that calculates to 5Ap-p current output, so there is no current limit before 100W.
The same cannot be said for a Single Ended Class A. In that case, the MOSFETs are biased to their mid-operating point. The power of the amp is then its Class A power only.
So if the Aleph 4 is SE, and 100W Class A, and the F5 is 100W Class A/B (25W Class A), they both have basically the same "driving" ability.
This assumes massive PSUs which don't limit anything. Have I made any massive errors here?
Having completed my own F5 amp, I would say it is good - very good. I'm not being down on it here, but I would say that it sounds like a very solid, well designed amp. Its not "out of this world", but I suppose what I would expect for a £2k transistor amp - and that was about its retail. Clearly, I'm pretty chuffed for the £400 outlay, but I do prefer my Sugden - the mid range has just a slightly more correct timbre to the instruments, and doesn't really loose anywhere else.
Of course, the main temptation now is to try another First Watt variation!
Old 11th March 2012, 06:53 PM   #129
F5 is for 1.3A bias current.
25w class A / 25w classAB / into 8 ohms
12.5w classA / 50w classAB / into 4 ohms
6.25w classA / 100W classAB / into 2 ohms
Old 11th March 2012, 07:17 PM   #130
Can you please explain why its only 25W Class AB into 8Ω? The Class A figures you give seem to add up to my calcs, but I cannot see how you arrived at the class AB figures. What am I missing?
Also, why do you say that the F5 is 1.3A bias? The comercial version was set to that, but as far as I can see, it will be a valid design at less than that (and maybe a bit more if you can keep the MOSFETS cool).
Just curious!
Pass F5 Help Needed vdi_nenna Pass Labs 34 12th July 2015 12:40 PM
Pass F4, F5 and Motif amps joda Swap Meet 2 24th December 2010 10:16 AM
Pass F5 clone parts for sale wirewiggler Swap Meet 2 9th April 2009 03:01 AM
PDF about F5 amplifier of Sensei PASS NihonJR06 Pass Labs 1 25th May 2008 05:27 PM
Copyright ©1999-2017 diyAudio
