Wattage of Pass F5 - Page 10 - diyAudio
Old 25th January 2012, 08:16 PM   #91
a.wayne is offline a.wayne  United States
Sin Bin
The quad is a 2 way ....
I'm sorry cannot concur with your observations, what you have described is a poorly designed multi-way speakers, more specifically there x-overs. Done correctly you could be standing less than 1 M away and cannot point out the drivers..
regards,
Originally Posted by ramallo View Post
IMMO multiway = multi point sources = multi-problems.
I heard and adjusted (and made) dozens of multiway systems, and my feelings is the best one is the one way (But is very difficult to achive a good performance, my Quad ESL can, but the drawback are a low headroom), the second best is two way, the third best is three way.........
But is my taste
Old 25th January 2012, 08:22 PM   #92
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
regards,
One way (ESL63)
Part of my work is adjust PA systems, I heard everything, from poorly designed to well designed, this is the reason on my oppinion.
Happiness is a warm soldering iron
Old 25th January 2012, 08:29 PM   #93
Which Quad is 2way?
Old 25th January 2012, 08:32 PM   #94
ramallo's Avatar
Originally Posted by TheShaman View Post
Which Quad is 2way?
ESL57
Old 25th January 2012, 08:34 PM   #95
Sin Bin
When you say Quad ... means "57" , all the others are ESL63, et al ....
Old 25th January 2012, 09:56 PM   #96
I can believe that ... Poorly made/designed speakers, nothing to do with them being multi-way. Done right , no single speaker or 2 way will come close...
Much easier to get a 2 way correct.....................
I think we are mostly in agreement, 2 way is easier. That said, when I've listened to multiways done correctly, there seems to a limited area of the listening area that gets the really good treatment, and not so good out of sweet spot. The last several years I have really gotten a kick building 2-ways with larger pro type woofers and compression drivers on constant directivity wave guides. There is something to this constant directivity thing, with its ultra wide sweet spots and extremely stable imaging. The crossover MUST be properly designed for home hi fi use, removing the shout and inserting or designing in compensation to match the compression drivers sensitivity to that of the woofer, and at the same time flattening the high end response for proper extension. In the spirit of the Econowave speakers Zilch designed and built is what these 2 ways I refer to are.
With your multiways, are you talking DIY or factory built commercial speakers? What are some of you favorites? I am mainly interested in speakers with high sensitivity/effeciency, because of some of the amplification I have been using lately requires it.
Thanks for the banter and responses!
Russellc
Old 26th January 2012, 02:30 AM   #97
expert in tautology
bear's Avatar
Originally Posted by pdhanwada View Post
What happens in case of double output mosfets.
pandu
Nothing much happens into an 8 ohm load. The quiescent current goes up if the amp is biased to the same voltage point. The power to the load is the same.
You could have 100 mosfets. Same.
Where more mosfets makes a difference is when you want to drive a LOWER Z load, because they require more current when the input voltage to the amp is the same (or the output swing is the same).
Someone figured the power based on the rail voltage. Take 1/2 the rail to rail voltage and multiply by 1.414 then apply ohms law. IF you want to spec it the same as all other amps are spec'd.
What I think some are losing sight of is that the gain of the F5 is rather a lot LOWER than a standard power amp. Most power amps tend to have about 25-6dB of gain. The F5 has about 10dB less gain. This makes it sound different than expected, the output level from the source has to be higher (that sounds different if it's a preamp with gain). And also how you build and bias the F5 causes rather substantial changes in the way it sounds.
Everyone is NOT listening to the same F5 amplifier!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 26th January 2012, 02:50 AM   #98
Sin Bin
Bear ,
You have played around a bit with the F5, what setup worked best for you , as far as quiescent current , type of build parts , dual outputs or cascode version ....
Old 26th January 2012, 07:05 AM   #99
ESL57
Ok, sorry, thought someone was referring to the current models.
Old 26th January 2012, 11:57 AM   #100
Bear ,
Right. Wayne you asked my question right out of your hands.
Would like to know which one is better for 90 db 8 ohm speakers.
Standard, double output, cascode version.
Pandu
Pass F5 Help Needed vdi_nenna Pass Labs 34 12th July 2015 12:40 PM
Pass F4, F5 and Motif amps joda Swap Meet 2 24th December 2010 10:16 AM
Pass F5 clone parts for sale wirewiggler Swap Meet 2 9th April 2009 03:01 AM
PDF about F5 amplifier of Sensei PASS NihonJR06 Pass Labs 1 25th May 2008 05:27 PM
Copyright ©1999-2017 diyAudio
