#71 |
I'm still waiting for this 'wall of text' about offset and biasing.
ZM, i did read that entire thread, didnt see much to do with its basic design theory, what i did read didn't strike me as scary or untouchable.. As for the transformer buzz, the idea of a dc component on the mains is, under doubt, as the buzz is 100% constant, 24/7. never changes no matter what time, load, power state. so i shall (at some stage) bench the unit, play with the transformer mounting and failing that, i will build a quicky 'dc blocker' and make my next move from there. |
#72 |
oh ...... wall of text
![]() probably tonight , after I finish today's to-does and also enjoying in first proper snow in my neck' o' wood you can imagine me as big moose , pulling those sleds ... you got all the parts ?
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#73 |
Well.
Interesting facts time...... From Pass Labs, amp was originally sold to hong kong in 03. in 06 they supplied some output trannies to the same hk dealer.... They have no idea how or when it got to Australia. never mind, i can handle that bomb shell... Now, measurements. amp has been on for several hours in use to warm it up and let it stabilise. no load or input connected. All done with a fluke 179. measuring those jumpers (prev labeled a/b/c/d) gives 0v071 and 0v069 nothing like the 0v94 ZM suggested.. total dc offset - - - - - - - - - - - - - offset ref chassis gnd. good side, 0v05 - - - - - - - - - - - - 1v9 - both 'pos/neg' outputs so close. repaired side, 0v001 - - - - - - - - -- 10v67 - both 'pos/neg' outputs so close. yes, thats right, one side is 1.9 v other side is 10.67 v. just a wee tiny difference. NOT. so, I reallllllly do think it needs a damn good reset.... I did retest the numbers several times, even grabed a second f179. exact same numbers... Sooooo, wheres that 'wall of text' I think i might just need it......... Parts, no not yet, was waiting till i can see whats involved in resetting them first. will start doing a shopping list tmrw. will include some electro's and trimmers. |
#74 |
what's heatsink temperature , when amp is fully warmed ?
here's the nomenclature
#75 |
didnt measure it (i should've i know) but id say ~45-50 on the 'hand burn scale'
#76 |
just for a giggle
turn it off , wait 5 mins ( to be sure that caps are bled down) and measure resistance between pins on each header A, B , C ,D while you're there - inspect visually values of those 3W Pana source resistors ;you can check them with DMM if you can't see the value something is highly illogical - amp is hot , even if DVM says it's seriously underbiased edit : just in case - I hope you measure voltage at headers when amp was fully ON , not in stand by
#77 |
ok.
each header pin is 1.2ohms source resistors look untouched, labeled as 0.47ohm and measured (in circuit) 0.6ohm, well, the ones i can get easy access to anyway. same on both sides. |
#78 |
that's completely logical and in line with each info I have
please confirm voltages at headers when amp is fully on ; point is that in stand by mode output stages are exactly non/under-biased as you measured
#79 |
ok, just plugged it back in (power that is)
filter caps are sitting at ~40vdc. in standby the jumpers are 0v000 powered up the jumpers are 0v06 but that is within a few minutes of it being 'turned on' so till cold. |
#80 |
wall of text : at UGS pcbs : P1 is for absolute offset ( offset between each/any output and gnd) ; must be 0V P2 is for differential offset (offset between outputs) ; must be 0V fiddling any of these will influence operation of previous one ; so - setting is iterative - in small increments - alternative fiddles of P1 and P2 at Motherboard : P1 and P3 are pots for biasing adjacent output sides of one channel P2 and P4 are pots for biasing adjacent output sides of second channel reference measuring points are nearby 2pin headers ; I need to confirm which pot is connected with which 2 pin header -will edit post later OK - that's sort of explanation ; do you need exact procedure written down ? edit : P4 - header A P3 - header B P2 - header C P1 - header D
| Boosting line out and adding low-pass | KiwiSteve | Car Audio | 4 | 18th June 2011 01:32 AM |
| Ask help on PASS X150 bias setting | aakkjj1999 | Pass Labs | 1 | 22nd January 2011 11:22 AM |
| pass x150.5 | barti | Pass Labs | 2 | 18th October 2008 04:03 PM |
| Pass X150 power down Thump solution = Jensen Isomax (RCA to XLR converter)?? | kmtkwong | Pass Labs | 3 | 10th October 2007 10:45 PM |
| Passive Line Level High Pass | noodle_snacks | Multi-Way | 6 | 27th January 2006 11:19 AM |
| Page generated in 0.10309 seconds (78.30% PHP - 21.70% MySQL) with 11 queries |
