F2J parts. - Page 3 - diyAudio
Old 6th March 2012, 07:44 AM   #21
oon_the_kid's Avatar
Looking at the circuit again, I noticed Nelson chose to put a 10uF for the power supply decoupling caps after the resistors. Any idea what type of cap it should be?
Thanks.
Oon
Old 6th March 2012, 10:16 AM   #22
Just checking the F2J shares the same power supply with the F1 right?
Oon
Old 6th March 2012, 07:04 PM   #23
cochleus's Avatar
Oon,
I'm using the same type used in the Zen 4 supply decoupling. Look at Digi-Key part EF1106. They are 10uF metalized polyester 100v
Power supplies for F1 and F2 are identical.
Cochleus
Old 7th March 2012, 12:39 PM   #24
ianc13 is offline ianc13  United Kingdom
Hi Oon,
With regards to your output cap have a look at this - only 63V (which is perfect in this circuit) but 470uF. It isn't cheap but at ~$30 but is maybe a 1/3 of the price of the 947c491k801cbms from Cornell Dubilier and would easily fit inside your chassis.
Audiocaps.co.uk - Arcotronics JSP
I don't know if they would ship out east, but you should be able to find other distributors closer to home.
Note: if you do decide to use audiocap.co.uk then they seem to be a good outfit - I ordered some capacitors and some clips from them, the clips were for different sized capacitors and they got in touch to make sure that I had not made a mistake when ordering which I thought was pretty good service.
It briefly passed my mind to use some of these in my F2J, but then I figured it would be ~$600 per channel for ~10000uF and then reality dawned
Old 8th March 2012, 03:19 PM   #25
Hi Ian,
Thanks for the tip. I think you made a small calculation error. The
One I was looking at was a bit cheaper.
For some reasons not clear to me this one is a lot cheaper than the rest.
Think will stick to this one. All for non audio reasons.
1) I want to have the dubious honour of being the first person on this forum to use a 1kg capacitor. Also with both channels, my cap will be heavier than my tranny. It's all about the bragging rights. Assuming nobody else have already beaten me to it. The capacitor is 4 inch in diameter and 5 inch long.
2} the other factor is, the jfets was developed for power inverters, so was this capacitor. So I thought it makes an ironic story... the pair working together...
3) On a different side of the matter. Using a much smaller capacitor does not reduce the bass response for the f2j. Since it is a current source the current will be the same on all parts of a series circuit. However the increase in impedance will reduce your maximum power output. It will be limited by your maximum voltage swing. The impedance of the cap will become significant at about 40Hz. So if you want to try it I believe the one 490uF you saw at the website will work. 2 might be better but 1 will be OK... In fact if you look up most op amp based low power single rail amplifier it is only about 1000 to 200 uF
Oon
Oon
Sent from my MB860 using Tapatalk
Old 8th March 2012, 05:07 PM   #26
Sorry,
I thought the 947c491k801cbms was $114 each on Newark/Farnell/Element14.
The stacked foil works out about $30 each (the $600 was if I wanted 10000uF, i.e. 20 per channel!).
Ian
Old 9th March 2012, 04:52 PM   #27
Interesting. It shows up s $27 in my part of the world. Maybe it is locality dependent. I chose that particular one because it was instock in Singapore. Maybe if you had chosen one that was in the UK, it might be cheap on your side and expensive in mine...
Oon
Old 9th March 2012, 07:34 PM   #28
Wow $27 for 1KG of polypropylene capacitor, you can't argue with that, I shall be interested in your listening impressions when compete!
Old 10th March 2012, 12:08 AM   #29
Hey you can try it too. The one you suggested is of the same value. And it doesn't cost much. And as I have mentioned, in a current source amplifier unlike a voltage source amp, the current is identical everywhere in a series circuit. So there is no roll off in the bass like a normal voltage amp. Just a limitation in power output in the lower bass region....
Oon
Old 10th March 2012, 03:00 AM   #30
JZatopa is offline JZatopa  United States
Any chance someone can try their f2j with a traditional speaker and tell us a bit about how it sound?
F2J schematic needed neazoi Solid State 1 6th November 2011 05:35 PM
F2J PCB: a question on ground layout Lazybutt Pass Labs 11 5th October 2011 12:04 PM
F2J power supply voltage?? holminator Pass Labs 6 15th September 2011 05:14 PM
nelson pass f2j f2 pcb psu board. bjcwolters Pass Labs 2 5th August 2011 08:32 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 05:22 PM
Copyright 1999-2017 diyAudio
