F2J parts. F2J parts. - Page 4 - diyAudio
F2J parts.
F2J parts.
Old 10th March 2012, 07:52 PM   #31
ianc13 is offline ianc13  United Kingdom
Hi Djnubz,
There would be an amount of rework to make a current source amp work correctly with a voltage source designed crossover.
Parallel crossover elements in a voltage source arrangement become series in a current source arrangement and vice versa.
You should read NP's article on current source amps at Current Source Amps
Old 10th March 2012, 09:31 PM   #32
JZatopa is offline JZatopa  United States
Ianc13 thanks for the link. I have paged through it and a few other articles by Mr. Pass on the subject. It was more of a, I know it's not supposed to work but has anyone tried it any way, question.
Old 15th March 2012, 12:44 AM   #33
oon_the_kid is offline oon_the_kid  Malaysia
oon_the_kid's Avatar
Hi djnubz,
I think the essence of it is the performance will be quite varied and unpredictable. So no matter what one says, you can't generalise for the rest. The issue here lies with the impedance curve for the speaker which will roughly translate to the 'frequency' response. So the peaks of the curve will become peaks in the frequency response. That is why it works better for simple single drivers. At least one can predict the impedance and hence compensate for it..
Oon
Sent from my MB860 using Tapatalk
Old 12th September 2013, 11:49 AM   #34
Alright. I finally got around to finish it. I must say the sound is gorgeous. The way it fills up the room with somuch emotion...
Picture included. Yup those two black things are my 490uf output caps.. polyproplene....
I stack my claim as the person who has used the biggest caps there is in his F amp...
Oon
Old 12th September 2013, 11:53 AM   #35
Old 12th September 2013, 01:16 PM   #36
zany is offline zany  Australia
great work oon, did you need any compensation network to get the F2j to play nicely with your speakers?
Old 13th September 2013, 03:25 PM   #37
Didn't use any however I used a bit of graphic equalizer in my software to reduce the shout. Might be good to add in a zobel network...
Oon
Old 14th September 2013, 03:45 AM   #38
thanks for the reply.
F2J parts.Hide this!Advertise here!
F2J schematic needed neazoi Solid State 1 6th November 2011 04:35 PM
F2J PCB: a question on ground layout Lazybutt Pass Labs 11 5th October 2011 11:04 AM
F2J power supply voltage?? holminator Pass Labs 6 15th September 2011 04:14 PM
nelson pass f2j f2 pcb psu board. bjcwolters Pass Labs 2 5th August 2011 07:32 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Copyright 1999-2017 diyAudio
