I recently acquired a set of BrianGT Aleph boards. The most current black ones, with the nifty break-away daughterboards for the big transistors.
Photo - ![]() As the Alephs are not the current 'super popular' project (having being supplanted by the F5 these days) the bulk of the information I can find is old, with lots of broken links and lost photos. Also, with Brian's website have been down for some time now, there is a notable lack of information. Does anybody have a known good schematic that works on those boards? There is room for up to 3 output devices/ current sources per channel, and it uses TO-220 size transistors for the drivers. I seems to me that an Aleph 3 or an Aleph 5 should work, and perhaps a mini Aleph. ?? Lastly is there any good information on making an Aleph into a headphone amp, like this -- 6moons audio reviews: Reality Check with Terry Aben ? Thank you in advance.
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 Last edited by 6L6; 18th January 2012 at 01:58 PM. |
#2 |
6L6,
I'm in somewhat the same situation, several years ago I bought a set of BrianGT Aleph boards and I'm just now getting around to building the amp. Two mini-aleph threads I found useful are: The Mini-A Mini Aleph Power Supply I attached a copy of the schematic diagram that I've been using. One thing you should be aware of is that one of the versions of the amp boards has a capacitor's polarity marked backwards on the board, I think it is C2 but you should compare with the schematic to be sure. The parts list for the amp is still available from chipamp.com http://www.chipamp.com/diyaudio/mini-A.xls, and I've attached a parts list I found for the power supply boards. Since the part lists were created several years ago a few of the parts are no longer available from Digikey. Here are the substitutions I made, these are not tested but as far as I can tell should work. Amp C5 (PS1H103G-ND) is no longer stocked, Digikey recommended P4513-ND instead. Power Supply D1-D4 (MUR1560OS-ND) is no longer stocked. Substituted MUR1560GOS-ND which is a RoHS replacement Heat sink for D1-D4 (HS184-ND) is no longer stocked. Substituted HS346-ND. I'm about to place an order with Digikey, but first I need to decide what to do with the CRC filter in the power supply. One option is to just use jumpers for R3-R12, another is to put in resistors to create a low pass filter. I posted some questions in the power supply thread I linked above, but haven't had any responses yet. Anyway, I hope this helps get you started. Be sure to post updates as your project progresses. - Matt |
#3 | |
I did it two years ago. Aleph J thread is not too long and informative enough. See attachment for AJ component numbers on this board (Red) |
#4 |
Also
#5 |
Also.
Red crosses = useless components Last edited by bobodioulasso; 18th January 2012 at 07:51 AM. |
#6 |
Great, I also have these boards...have a few, wanted to build a mini or a 30, and mainly I would really like to build a pair of Aleph 2 amps...
Russellc |
#7 |
Wow! Great info so far! Thanks so much!
Does anybody have a Aleph 3 or 5 schematic with the same part numbers as the board?
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#8 |
#9 | |
This is a great thread! There is just too much information in the hundreds of pages of all the other mini-Aleph threads... |
#10 |
This should get you started - for the mini-a or a30 configurations.
| BrianGT boards....replacing a few parts? | wboyd | Chip Amps | 2 | 27th August 2007 08:39 PM |
| transformer with 3886 (BrianGT Boards) | mantisory | Chip Amps | 2 | 3rd May 2005 02:59 PM |
| BrianGT rev B boards -- What to do now? | AAXenoStrange | Chip Amps | 1 | 20th December 2004 01:38 AM |
| WTB: BrianGT LM3875 boards | guzzler | Swap Meet | 1 | 10th December 2004 10:34 PM |
| Wanted : BrianGT Aleph 2 boards | dhole | Pass Labs | 0 | 5th December 2004 10:05 AM |
| Page generated in 0.10568 seconds (81.68% PHP - 18.32% MySQL) with 11 queries |
