Aleph with BrianGT boards
Old 19th January 2012, 10:29 PM   #21
pchw is online now pchw  United States
zeoN_Rider,
Gmail bounce back when I sent to your email address. The error was:
Delivery to the following recipient failed permanently:
XXXXXX@sezanpro.rs
Technical details of permanent failure:
DNS Error: Domain name not found
I tried to PM you my email address, but your settings block all PM.
I will try again later to see this is gmail hiccup.....
- Fred -
Old 21st January 2012, 01:56 AM   #22
dmsims is offline dmsims  United Kingdom
Experienced users look away now!
Aleph 30
I am doing exactly the same as the OP
have built and tested the PSU board and waiting for the case by sea
any comments welcome
Old 2nd April 2013, 11:07 PM   #23
Freecrowder is offline Freecrowder  United States
I realize this thread goes back a little over a year but I'm in the same boat. i have the BGT boards also and wanting to build an Aleph. Correct me if I'm wrong but this board set could be used to build any of the Alephs correct? At least the Vgain stages are the same that I can tell from KK schematics online. I'm interested in building Aleph 4 which I believe is stereo 100W/channel??? Would love some feedback from someone that has used this boardset. Also wondering about the prior post showing red x on un-used or not needed parts.
Old 2nd April 2013, 11:15 PM   #24
AudioSan is offline AudioSan  Norway
do you need it to be a stereo amp? aleph2 monoblocks is a better option.
and yes. you can use those boards for any of the aleph's. just get some extra output boards. you can also build any of them with J-fet input stage.
Old 3rd April 2013, 05:36 AM   #25
6L6 is offline 6L6  United States
6L6's Avatar
Freecrowder - Yes, you can use those boards to build any version, just add more output boards as AudioSan says.
The first thing to do is determine how much heatsink you have/need. That will determine how much amp you can have. A decent rule of thumb is about 5X5 (or more) inches of finned heatsink per mosfet.
Yes, it adds up fast, and yes, anything more than about 40-50WPC needs to be monoblocks. (Unless you like enormous amp boxes)
Old 3rd April 2013, 01:32 PM   #26
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Since the BrianGT output boards don't fit the DIY Store universal mounting spec, I wonder if the BA-1 output boards could be adapted to serve as output boards for an Aleph?
Old 3rd April 2013, 03:15 PM   #27
6L6's Avatar
Taking a quick look at it, yes, I think it would work.
Great idea!!
Old 3rd April 2013, 05:43 PM   #28
biju55 is offline biju55  India
biju55's Avatar
I am building an Aleph 30 with this PCB
Old 4th April 2013, 12:28 AM   #29
OK, thanks for the replies guys. I know this is old thread. I plan on using vertical heatsinks from industrial drives. 24" H, 8.25 W, 2" deep fins. It will be vertical amp like a Mark Levinson. I have many more questions so I hope I don't impose. I want to use IRFP250 in the output stages because I have many laying around. Can I substitute those with out changing any other components? What is meant by the the BGT output boards not to DIY store spec. Is there some reason I can't use them. Finally are there some components on the front-end boards that are not used. Help is greatly appreciated. BTW I built the Pass A40 using same heatsinks and the temp on them are barely warm to the touch on a cool day. Is there a schematic showing part numbers for these boards?
Old 4th April 2013, 01:24 AM   #30
6L6's Avatar
I think this has the proper part numbers -
From this page - Aleph 30
There is lots of fantastic info there.
Aleph with BrianGT boardsHide this!Advertise here!
BrianGT boards....replacing a few parts? wboyd Chip Amps 2 27th August 2007 08:39 PM
transformer with 3886 (BrianGT Boards) mantisory Chip Amps 2 3rd May 2005 02:59 PM
BrianGT rev B boards -- What to do now? AAXenoStrange Chip Amps 1 20th December 2004 01:38 AM
WTB: BrianGT LM3875 boards guzzler Swap Meet 1 10th December 2004 10:34 PM
Wanted : BrianGT Aleph 2 boards dhole Pass Labs 0 5th December 2004 10:05 AM
