Building a Pearl 2
Building a Pearl 2
Old 17th June 2017, 07:25 PM   #901
laverda is offline laverda  United Kingdom
Out of interest, what is the preferred 22uF output cap other than a litic ?? Film/Polyprop?
TIA
Old 17th June 2017, 07:53 PM   #902
flancfuster is offline flancfuster  Romania
Where did you get the self-adhesive mu-metal sheet? I want to install it to my pearl 2.
Originally Posted by folkdeath95 View Post
Thanks.
The white thing in the case is self-adhesive mu-metal sheet.
"Without music, life would be a mistake." - Nietzsche
Old 17th June 2017, 08:22 PM   #903
folkdeath95 is offline folkdeath95  France
folkdeath95's Avatar
Mumetal, Nikel Permalloy, Magnetic shielding foil, Sheet, Mu-metal 0.1T-a | eBay
Petite Onken/Altec 414-8B+Altec 808-8B/GPA aluminium diaphragm/Altec 811; Firstwatt Aleph J Clone; Denon DP5000F; Sphinx Myth9 MkII
Old 17th June 2017, 10:50 PM   #904
Eric is offline Eric  United States
Eric's Avatar
Building a Pearl 2
TIA
You'll have a tough time finding anything but a litic in 22uF size, but I found this cap unnecessary after adding a cap in series with R14 to ground. Just lift the ground side of R14 and connect to the + lead of the cap and the - lead goes to ground. A bipolar cap would work here also but a standard electrolytic will work.
See the discussion here
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 18th June 2017, 02:11 AM   #905
wayne is offline wayne  United States
In the hills
Building a Pearl 2
I like the mu metal shielding a nice touch and it does help.
wizards assistant
Old 18th June 2017, 07:23 AM   #906
You can find polypro, PIO, etc... caps in 22F, but they are huge. But if Laverda has enough place in his box, he can try.
I understood that this output cap was a high-pass filter to prevent any DC to go to the next component (preamp, amp, etc...). I suppose it's possible to get rid of it if you have a input cap in your preamp, but I didn't know that the cpa in serie with R14 had the same effect.
Concerning this cap: given that R14 sets the gain, does adding a cap in serie with it changes something in the gain?
Old 18th June 2017, 07:24 AM   #907
Thanks Wayne.
Old 18th June 2017, 10:45 AM   #908
...all clear now...I've already done the C in series with R14, so I'll whip out the 22uf and see.... Many thanks.
Old 15th August 2017, 08:04 AM   #909
Wellerman is offline Wellerman
Lately I have noticed that my Pearl 2 doubles as a tuner as among the background noise a radio station can be heard. Very low level but audible when a silent groove is played. This disappears when I disconnect the turntable. So I suspect it must have something to do with the new interconnect that was mounted on my Thorens (functions as an antenna?). Is there anything I can do to the Pearl to make it less susceptible to this?
Old 15th August 2017, 01:31 PM   #910
McQuaide is offline McQuaide  United States
If it disappears when you disconnect the TT, it's the TT picking up interference not the phono pre. The pre is just amplifying it. Look at the shielding of your phono from the cartridge all the way to the Pearl 2.
Building a Pearl 2Hide this!Advertise here!
RIAA caps for Pearl and Pearl 2 AudioLapDance Pass Labs 7 22nd May 2015 07:19 PM
pearl HELP! d to the g Pass Labs 24 31st May 2007 01:56 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
Anyone building a pearl phono soon? mattjk Pass Labs 8 24th March 2005 12:20 AM
The Pearl-X Vince Maida Pass Labs 12 28th July 2002 07:28 AM
Copyright ©1999-2017 diyAudio
