Aleph OPS as a differential amplifier.  Possible?
Old 22nd January 2002, 11:13 PM   #1
blschuler is offline blschuler  Canada
Question Aleph OPS as a differential amplifier. Possible?
I'm wondering if two Aleph output stages when put together could be used as a differential amplifier? Perhaps the active current sensing (feedback loop) won't allow for it and canncel out any gain/signal? If not maybe it would create a voltage doubling situation?
Any help appreciated.
Brett
Old 22nd January 2002, 11:44 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It'll work fine, in fact, an example will be used in a
future version of Son of Zen project. You can bias these
two where they join at the Sources of the bottom
transistors with a current source, or if you have a balanced
input signal, a resistor.
Old 23rd January 2002, 01:53 AM   #3
paulb is offline paulb  Canada
I have to say, Nelson, these little hints of things to come at passdiy are sure enticing. I'm having trouble planning the project after the project after my next project.
Thanks for giving us some idea of what's coming up.
Old 23rd January 2002, 03:00 AM   #4
Thanks Nelson.
More questions.
So if I am understanding things correctly a differential amplifer using the Aleph curcuit would be a very low distortion OPS for two reasons: 1. The noise cancelation inherent to a differential design which is (correct me if I'm wrong) the reduction of just random/floor noise by about 90%. 2. The reduced signal distortion beyond conventional constant current sources (as stated in the Aleph patent) which is due to (I think) the local (or is it negative?) feedback this type of active current sourse creates.
Brett
Old 23rd January 2002, 03:47 AM   #5
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Well here goes. This is my first post on this site.
Let me know if I'm mistaken, but this amp design sounds like an FET version of the A40 without the local feed back. Yes? No? Maybe?
Rodd
Old 23rd January 2002, 04:31 AM   #6
Hi Rodd, What I am awkwardly talking about is a differential single-ended class A output stage like the SOZ but with the Aleph type constant current sources. The A40 I believe has a push-pull class A OPS. Push-pull and differential OPS types both offer noise reduction (symmetrical cancelation?) that is not inherent to a single-ended OPS.
Brett
Old 23rd January 2002, 05:33 AM   #7
Joe Berry is offline Joe Berry  United States
The attached schematic may not be quite what you have in mind, but at least shows one approach along the lines you suggest. This example uses constant current sources rather than Aleph current sources, but I see no reason why you couldn't substitute the Alephs in there (assuming non-commercial use, of course).
I should also note that this design incorporates conventional balanced feedback rather than supersymmetry as used in the Pass X series. Also, as it has two stages, it is not a true Zen variation. In fact, you might think of it as a bridged pair of JLH 10W class A amplifiers done with MOSFETs. BTW, the values shown would give you about 35W rms into 8 ohms.
I can only offer this for your amusement as I've not actually built a working example. There may be a problem in practice with excessive DC offset drift, and you will certainly need to make either the input stage current sources or their drain load resistors adjustable so you can properly balance the output stage.
Old 23rd January 2002, 07:27 AM   #8
Thanks Joe, I haven't been able to find much out there for amps using a differential OPS, SOZ being the exception.
Certainly the schematic you posted is very close to what I would to eventualy like to build. I was just thinking of a Aleph amplifier modifyed with a differentail OPS. So yes two stages. I still trying to figure out what the best input stage/feeback configuration might be. Perhaps eliminating the global feedback altogether is a possibility.
Refering to your schematic the feedback from the final stage feeds into the Source pins instead of the gates. Why is this done? I think I might know why but I guess wrong to often.
Brett
Old 23rd January 2002, 08:06 AM   #9
jam is offline jam  United States
jam's Avatar
Joe,
It would be interesting if you built it. I wound suspect that you would need a servo to compensate for dc offset.
Jam
Old 23rd January 2002, 09:11 AM   #10
Default How about this?
Okay, here's a more conventional take on the same basic idea that, as such, may be easier to follow. It is also not likely to suffer from offset drift problems. Again, we are dealing with a conventional bridging configuration, not an X type design.
My reason for omitting the input differential pairs from the first design is that a pair of diff pairs is -- well, at least rhetorically redundant, if not functionally so -- in a topology that is itself differential. (As the Zen aphorism has it, "the garden is finished when there is nothing left to remove.")
More to the point, although the diff pair is usually regarded as a single stage, it does add an extra time constant to the overall feedback loop, and for this reason IMO it should not be used indiscriminately. I'll admit that this probably is not a major issue in the context of a two-stage amplifier, but it can be a problem in more complex designs.
Aleph OPS as a differential amplifier.  Possible?Hide this!Advertise here!
Help with designing differential amplifier krish2487 Solid State 12 24th February 2009 03:07 AM
Differential to differential amplifier Cauhtemoc Solid State 3 15th August 2007 08:39 AM
Differential amplifier mystery? klitgt Digital Source 0 7th March 2006 03:07 PM
max. differential voltage in an Aleph P rsbay Pass Labs 1 28th February 2005 09:31 AM
differential amplifier Thomas Giz Digital Source 1 23rd March 2003 09:07 PM
Copyright ©1999-2017 diyAudio
