#11 | |
Heja Knut,
?Other FET variations is to be found in the gigantic JLH-thread. JLH is a nice topology anyway! |
#12 |
Thank you for your interest. Hopefully I will be finishing the assembly in about two weeks. So I am looking forward to the first listening test after that....As always: enough time is a problem.
#13 | |
Unusually I have too much time on my hands......and not enough brains
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#14 | |
And I agree with you about the topology. |
#15 |
I smell something burning
#16 |
Data sheet for the JFET: http://www.fairchildsemi.com/ds/MM/MMBFJ177.pdf
#17 |
That's very interesting amp indeed. Some DIY-ers are concern about resistors and capacitors. More advance care about transistors. But there is more in what comes out of speakers - sound characeristic i.e. harmonic distortion content. With PLH one can change from Push-Pull signal amplifing method to Single Ended, or choose and many stages between the two. (Like 2/3 AC current ratio suggested by Nelson). From this point of view it's very interesting to see in what extent sound change accordingly. That's why I think every DIY should built PLH but probably only some understand what it's about. I would like to build a one. Knut your cirquit is particulary interesting since there are no capacitors at the output, so one thing less to bother. Looking forward your final results. Thank you for PCB drawings. Pawel
#18 |
Hej Knut,
Can you inform us about the current status of this project? Regards, John |
#19 |
Those that find this amp interesting, may also find the Amp Camp Amp #1 interesting:
Amp Camp Amp - ACA (The designer has a decent reputation )It has some similarities:
And there is going to be a kit for it including parts (not just PCB) here at DiyAudio I would have thought quite the opposite, far more to bother with, like DC offset adjustment and drift for example, and making sure voice coils don’t get fried. I can’t help thinking people make a bigger deal about having the cap. before the speaker as opposed to after it in the power supply, though I have not done subjective testing on this. Psychologically I guess it does provide less to bother with because the power supply schematic is typically drawn on a different page, so you don’t see the rail caps, just a pretty ground symbol , even though it’s still in series with the speaker, out of sight out of mind. In some cases when the cap is made too small I guess that can have an effect on base. I change my own mind on this topic all the time and can argue both sides of the fence. |
#20 |
I've got First Watt F3 with nice battery of 15 ELNA silmic II capacitors per channel and that's very impressive amplifier. It's a pity I don't have time to finish PLH project. PCB's are waiting for their turn.
| All FET JLH Class A | EUVL | Solid State | 14 | 6th August 2012 03:10 AM |
| JLH/PLH PC Boards? | Winding Man | Pass Labs | 16 | 28th January 2012 02:11 PM |
| Line preamp for JLH/PLH? | tmblack | Pass Labs | 12 | 1st November 2011 05:54 PM |
| J-JLH or PLH-J ? | drjbf1 | Pass Labs | 11 | 28th July 2011 01:37 PM |
| JLH Class-A Amplifier | Geoff | Solid State | 5 | 25th May 2001 11:55 PM |
