Hello someone updated the preamplifier PASS LABS X2?
The capacitors are very cheap and spoil the circuit resistance impreso.El problem is in the size of the capacitors capacitors to know someone. thanks |
#2 |
#3 |
hola yo quiero cambiar los condensadores por unos mejores y si se le puede hacer alguna mejora en los demas componentes.
#4 |
Google Translator say:
" hello I want to change the capacitors by better and if you can make some improvement in other components " Yes, for sure...you can change cap's to better performance. What X2 version do you have?there are X2 1's version, 2's and 3's version. And, avaliable schematic just for X2 1's version... |
#5 |
hola yo creo que es la version x2-1 ,de todas formas como lo puedo saber.
gracias |
#6 |
The X2 have a good capacitors inside, IMMO a step up capacitor (In quality) are too big for this unit (V-Caps or something like this). My advice is leave the unit like is, and make a new X2 with a proper size pcb for big capacitors.
P.S. I recently bought a Aleph L with a disastrous mod, someone changed the resistor level control by a Alps blue potentiometer, arggg!.
Happiness is a warm soldering iron
#7 |
What should the Aleph L have had as standard ?
#8 | |
It's not against your language but the fact that others can not understand you! Thanks, Muchas gracias ! José Auidofanatic
Be nice to animals. |
#9 |
Have a stepped attenuator (resistor) (Much better track than a Alps) close to Goldpoint units
![]() The v1.2 have the same attenuator with two circuits (Part of the run are in passive mode)
#10 |
Surely the choice of the attenuator is down to the constructor.
I actually prefer the ALPs pots. Until such times as someone produces a 40 step ladder attenuator. (or more) |
| Pass Labs X2 REV1 Relays? | Mad_K | Pass Labs | 20 | 22nd January 2012 12:27 PM |
| Pass Labs X2 $1100 | Michael Rothacher | Swap Meet | 0 | 2nd May 2010 08:42 PM |
| FS: Pass Labs X2 preamp | Studley | Swap Meet | 0 | 18th January 2007 10:53 PM |
| The Pass Labs X2 - service manual | Asen | Pass Labs | 14 | 19th September 2006 09:17 AM |
| Pass labs x2 gian problem | AH JUI | Pass Labs | 0 | 27th February 2004 03:04 PM |
| Page generated in 0.10186 seconds (75.89% PHP - 24.11% MySQL) with 10 queries |
