Hello
Yesterday I changed the connections between Stereoknight Enigma preamplifier and my Threshold SA/4e S/550e that I use in bi-amping system with B&W 802D through a connection of unbalanced RCA to balanced XLR. The balanced cables are pro Extron Electronic with Neutrik connectors while the unbalanced cables are more complex DIY cables (I don't know the specs) homemade by a friend. I have noticed some changes in the perceived sound: 1 - The sound is slightly drier and lost a bit 'of body and thick, it all seems a little' thinner. 2 - The bass is less clear, with less impact and the attacks of the low notes are less precise and less fast. What can cause this problem? How can it be solved? In a few days I'll have to keep away from the amplifiers pre-amp so I will need about 6 meters of cable which should be, necessarily, balanced type. A friend of mine who owns a s/550e told me that he found the same problem, but fortunately he does not need to use long balanced cables... So I need an explanation to this problem and possibly a solution. It may be helpful to change the unbalanced input of the amplifier circuit (if I remember correctly the final threshold do not have a truly balanced circuitry)? If you can how? Thanks in advance Giovanni |
#2 |
The input on balanced was a true 600 Ohms on these if I remember correctly. This can be tough to drive and alter the sound some. It could be increased though.
#3 |
Gee, we had some S/500's at Telarc, I didn't realize that they had 600 Ohm inputs.
Kevin |
#4 | |
If I remember S/500 has only unbalanced inputs, S/550e and SA/4e are different from S/500, they have balanced inputs too. With unbalanced inputs the sound is OK! Thanks Giovanni |
#5 | |
Thanks Giovanni |
#6 |
I will see what I can find on Threshold. Didn't think to take much when I left.
#7 |
#8 |
You can check input impedance with an Ohm meter on this and verify.
It can be increased by changing R1 on the rear panel board and R2 on the front end board. |
#9 |
| Threshold SA/4e vs SA/1 | BrianEno | Pass Labs | 62 | 17th July 2011 01:31 PM |
| Threshold SA/4e and SA/2 | Mywing | Pass Labs | 8 | 4th January 2010 10:45 PM |
| Threshold S/550e to SA/4e conversion? | Barry1 | Pass Labs | 2 | 1st January 2009 04:43 PM |
| sa/12e or sa/4e or s/550e | jfrago | Pass Labs | 9 | 23rd August 2007 07:14 PM |
| Threshold S/550e Info | EchoWars | Solid State | 7 | 9th July 2006 06:03 AM |
| Page generated in 0.10707 seconds (79.79% PHP - 20.21% MySQL) with 11 queries |
