Old 16th September 2003, 06:44 PM   #1
Default More Pearl questions
This has been a long time in the making but I've finally buckled down to build it.
The good news is that there is no 'silicon ash' and second, there is no annoying hum. So far so good then...
The problem is this; I have played a record but it seems to have less gain compared to another phono stage (ESP P06). Yet I understand both are 40dB gain. The second is that it sounds restrained compared to the above. At this point I must add that C14 and C16 are NOT in circuit, nor is R1. I suspect this may have something to do with it but I am unsure as to what values to use with a Dynavector 10x4 cartridge(MM).
Output coupling capacitors are Mundorf MCap 630.
Any ideas? Always appreciated.
Cheers.
Brownlow
Old 17th September 2003, 10:27 AM   #2
Default Pearl
Your cartridge is a high output MC. Loading it at 47K with no added capacitance should be fine.
Try running it a few more hours to fully break in. If the gain is lower than your normal phono stage it can make the lower gain unit sound less dynamic.
Another possible area is the preamp used with the Pearl. Are you using a linestage or a passive to drive the amp?
George
Old 17th September 2003, 06:24 PM   #3
Panelhead,
Thanks for the reply, I will try that resistor fix. It is a good point that you raised about the gain. As you said, I will run the Pearls in a bit. We'll see what happens.
Also, the preamp is not passive.
Cheers.
Brownlow
Old 17th September 2003, 06:29 PM   #4
I've used the Pearl with a Dynavector 10x4 for many months. If I remember, all I had was the 47K input resistor. I know I experimented with adding small caps at the input to see if it affected the sound, but I don't remember what I finally ended up with, probably nothing.
And as Panelhead said, reduced overall gain in the system can sound restrained.
Old 29th September 2003, 01:59 PM   #5
What have I done...
I must admit I was a little concerned about the Pearl as the sound that I was getting wasn't that special. My output coupling caps are Mundorf MCap63 10uF. I remembered that I had some Audyn MKP-QS 10uF caps, I put these in and BAM! It kicked in. I have been listening to a number of discs and that midrange is sooo rich and full to me. This is clearly a great sounding phono.
On a different note, I thought that Mundorf and Audyn came from the same source. They sounded so different. The Audyn came in at less than half the price. Anyone tried the Audyn MKP-Plus?
Nice, very nice phono. Now I know why I've been missing out.
Cheers.
Brownlow
Pearl Phono questions Fitz Pass Labs 7 11th January 2009 02:36 PM
Pearl questions lykkedk Pass Labs 4 8th March 2007 02:33 PM
A couple of Pearl questions WindChill Pass Labs 3 8th June 2006 01:49 AM
Questions about Pearl..... Buhl Pass Labs 11 6th June 2005 01:16 PM
pearl phono questions rexrex Pass Labs 1 9th August 2004 05:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
