Old 22nd December 2011, 04:52 PM   #1
BeaufortRalph's Avatar
Default Help - Zen4 running too cool
Good morning - it is snowing again here in northern New Mexico - a perfect day for working on projects. I have a problem with my Zen version 4 which I built about six years ago in 2005. It worked well until last year when I fried one channel (all my fault).
I have just had the chance to repair it - we spent a year touring the country looking for a new place to live and the zen travelled in pieces under the settee in the travel trailer.
The problem it that the repaired channel runs cold - the heat sink barely gets warm, while the other channel functions as a heater as well as an amp. When replacing parts, I found that some parts were not available so I substituted as follows:
Digikey part numbers:
IRFP044N-ND to IRFP044NPBF-ND
The recommended IRFP240 to IRFP240PBF
Voltage readings as follows:
Cool (repaired) Warm
Vin 51.8 51.4
Across R0 .65 .661
Q1 D to gnd 27.76 27.8
Q2 D to S 12.23 12.08
Both channels are showing about 1.5 volt peaks at the speaker terminals at a low listening level
The heatsinks are 12” x 15” with 2” deep fins
Any thoughts?
Thanks, Ralph
Old 22nd December 2011, 05:10 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
taking in account that most important voltage - across R0 ( then also current) is similar in both channels ......... I resume that you have poor thermal contact between new mosfets and heatsink
they're (mosfets) nearly scorched , while heatsink is cold
clean well mosfets , micas and heatsink , reapply thermal goo between mosfet-mica and mica-heatsink , squeeze da screw tight and well .
use biggie washer between screw and mosfet
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 23rd December 2011, 02:44 PM   #3
Default Thanks, but still running cold!!
Thanks for your answer. I thought that sounded like it must be the problem. Got busy with some work stuff and did not get a chance to check it out till this morning. I checked the tightness of the mosfets (mounted on silpads) and did not find any problems. Decided to measure the temp of each mosfet before dismounting the board and cleaning...
Here are the results after about 20 minutes of operation at around 65˚ F:
repaired:
Q1 - 83˚
Q2 - 85˚
Q5 - 83.5˚
R1 - 86.6˚
Center of heatsink - 80.5˚
not repaired:
repaired:
Q1 - 133˚
Q2 - 109.5˚
Q5 - 104˚
R1 - 104˚
Center of heatsink - 105˚
Temperature measurements taken adjacent to mounting screws and in center of resistors
Anyone have any thoughts?
Old 23rd December 2011, 02:53 PM   #4
MRupp is offline MRupp  Germany
MRupp's Avatar
here are mine: The current sensing resistor could be somewhat damaged and has too high resistance (R0, R1, not sure if you have several in parallel, then one of them might be kaputt), or the VBE transistor Q3 could be damaged. Also, did you measure VGS for all MOSFETS ?
Martin Rupp
Old 23rd December 2011, 03:01 PM   #5
Vgs around 4 volts on Q5,Q2both channels
Q1 3.0 hot channel
3.5 cool channel
Old 23rd December 2011, 03:05 PM   #6
Voltage drop across R1 and R0 within 0.007 on both channels
0.636, 0.643
Old 23rd December 2011, 03:11 PM   #7
Q3 Ve to gnd 27 on hot channel and 32 on cold channel
Old 23rd December 2011, 05:47 PM   #8
Zen Mod's Avatar
look at attached pic ; all important voltages are here
open this pic in any editor ( MS Paint) and write down your voltages in , say, red
most important now - connect your DMM as Ampermeter ,in series with + voltage and read what current is going to channel
(naughty Papa - he deleted post )
Old 24th December 2011, 01:42 AM   #9
Default Still can not figure it out
I took some more measurements this evening. I guess the one that tells the tale is that the "cool" channel is drawing .5 amps at the fuse while the "normal" channel is drawing 1.37 amps.
While some of the voltages vary from those on the schematic, both channels are very close.
Does anyone have any more ideas?
All help is appreciated
Q1 Vsg 3.5
Q2 Vsg 4
C5+ R11 36.48 but both channels close to this value
Many thanks, Ralph
Old 24th December 2011, 05:00 AM   #10
Zen Mod's Avatar
it's already written - you need tp desolder those big resistors and check them with ohm-meter
best - against new ones , to exclude DMM low value treshold from process.
or even better - replace them
Zen4 problem cka3o4nuk Pass Labs 0 31st August 2010 06:54 AM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Aleph2 or Zen4?? porfi4ever Pass Labs 7 1st March 2003 06:05 PM
Yet another Zen4 completed jag Pass Labs 36 29th November 2002 10:57 PM
Cool running MOSFETS ding Solid State 8 17th June 2001 06:27 PM
Page generated in 0.10056 seconds (82.58% PHP - 17.42% MySQL) with 11 queries
