aleph p + attenuator
Old 15th September 2003, 01:42 PM   #1
george a is offline george a  Australia
Default aleph p + attenuator
Hi All
There seems to have been some talk about an alternative methos of signal attenuation in the BOSOZ designs which relies on effectively placing a potentiometer between the +ve & -ve outputs. There by avoidong the complexity and cost of relay based or the precision 4 ganged stepped attenuators.
has anybody tried this on the Aleph P1.7 preamp design or have any comments suggestions.
What happens when the pot resistance drops to zero ( at minimum volume) ie effectivley shorting the +ve and -ve outputs together- is this a bad thing?
thanks and regards.
george a
Old 15th September 2003, 01:54 PM   #2
UrSv is offline UrSv  Sweden
UrSv's Avatar
That would be a bad thing for the attenuator itself. Fortunately there is a 100 Ohm resistor on the output for each output that makes it possible giving a minimum of 200 Ohm across the output.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 15th September 2003, 03:11 PM   #3
till is offline till
Banned
16*2 Relays
3.90 PIC MC
< 10 for resistors, transistors, PS
Old 15th September 2003, 11:14 PM   #4
Thank you Ursv & Till
I forgot about the 100ohm resistors, but still i wonder if thers might be a probklem as my understanding of the circuit implies there is usually a greater load on the outputs than i would be providing.
As for cost and complexity- I do not understand and therefore am uncomfortable with digital electronics.
Same problem trying to fix a car with electronic fuel injection compared to one with a carburettor (to me at least ).
Any other comments out there?
george a
Old 16th September 2003, 04:02 AM   #5
mefinnis is offline mefinnis
mefinnis's Avatar
Default Hi George
For once in my life there is someone on the list who lives in the same city
Thus we are collaborating somewhat on this project and while I am less worried about cost (I already have my relays), the single attenuator across the output would simplify things considerably.
I have a working BLS to "play" with but I was wondering the best approach in terms of pot placement.
Alas, I posted to another thread:
http://www.diyaudio.com/forums/showt...994#post235994
Any comments from the learned ones .... !
regards
mark
aleph p + attenuatorHide this!Advertise here!
Aleph P1.7 attenuator to match imp. Bengali Pass Labs 5 26th August 2008 04:29 AM
Aleph P1.7 relay attenuator help needed tvnorm Pass Labs 10 31st August 2006 02:35 AM
Attenuator for the Aleph P folkeb Pass Labs 2 1st June 2006 04:21 PM
Attenuator on my Aleph P 1.7? RJEL Pass Labs 8 30th July 2004 08:37 AM
Aleph P input attenuator ElectroNick Pass Labs 1 16th September 2003 09:28 PM
Copyright ©1999-2017 diyAudio
