I have been studying for a couple of days the variety of PS Filter caps to use in my Pass design Adcom GFA-555 amplifier. For one it seems there are not a huge variety of 15000uf 100v caps out there to be had. I have scoured the earth and am leaning toward a Vishay PHR-ST type. $38 a pop.
Max ESR 16 Mohm @ 100hz. Rated ripple current @ 100hz = 12.3 What have others used for this amp design? |
#2 |
Done and done. Ordered the Vishays from Digikey along with 3.9kOhm 3W Metal Film resistors which reside on the filter caps at this time. Might as well replace those too. I would like to know why those resistors are there as bleeders though..............
#3 |
The one and only
For safety. If the rail fuses are blown, high voltage can sit on those caps
long enough to zap a technician.
#4 |
I have been selling the 22,000Uf 100V caps as replacements
http://www.apexjr.com/images/AdcomCap.jpg There $23.95ea and have 23 left in stock Steve @ Apex Jr |
#5 | |
Happy Holidays and thanks again. |
#6 |
Would you bring the amp up with a dim bulb tester after all 4 filter caps are replaced or just put your foot on the gas.
#7 |
if you are sure in your work - just put foot on the gas
if you have doubts in your work , use bulb safety thingie
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#8 |
#9 |
Rather than just switch on the amp after working on the PS, you should remove the rail fuses between the PS and amp circuit, and check the PS alone. This way you'll only blow the PS and not the amp if something's wrong.
#10 |
| DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM | stevep314 | Analog Line Level | 0 | 10th August 2010 09:15 PM |
| 1st order low-pass filter, which cap ? | Thmartin | Parts | 4 | 17th November 2005 08:37 AM |
| Active Band Pass Filter Design... | xitronics | Parts | 8 | 6th June 2005 06:01 AM |
| adcom gtp 500ll tuner problem, Nelson Pass maybe? | crippledchicken | Pass Labs | 11 | 21st January 2004 11:36 PM |
| Low pass filter design for TDA1541 | Zodiac | Digital Source | 23 | 25th September 2003 01:14 PM |
| Page generated in 0.10096 seconds (82.98% PHP - 17.02% MySQL) with 11 queries |
