Old 22nd November 2012, 01:54 PM   #31
expert in tautology
bear's Avatar
Hannes, see post #17... that is the difference in the parts I acquired between them and the original. Idss measured fine.
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 23rd November 2012, 07:03 AM   #32
h_a is offline h_a  Europe
h_a's Avatar
@bear:
do you have a tip for us how to determine the transconductance "on the kitchen table"?
Transconductance is change in drain current for a given change in gate-source voltage; means measure IDSS (VGS=0) first, then insert a source resistor (VGS!=0) and measure ID. Divide the differences and you have an approximative transconductance value.
It's not so straight forward as transconductance depends a lot on the drain current, but this way should be sufficient to distinguish a genuine high transconductance jfet from a low transconductance part with both having the same IDSS.
Alternatively (but less practical), one could measure pinch-off voltage (when the jfet stops conducting), because that is very different also; for K170 it is about -1-2V VGS or so, for long channel low transconductance parts about -3-4 VGS or so.
Old 23rd November 2012, 09:44 AM   #33
nr12 is offline nr12  Germany
ok, thats easy to do.
As I have some genuine K170 to compare this is ok for me.
Thanks!
Idss matched 2SK246 Y NYCOne Swap Meet 0 26th July 2011 10:03 PM
What is the correct Idss of jfet? Sunsun22 Parts 5 9th January 2011 12:31 PM
High Idss 2SK170GR? Sweetsweetback Parts 2 31st October 2010 11:40 PM
High Idss jFETs AndrewT Parts 24 30th October 2008 02:50 PM
Spice: how to set IDSS etc? bear Solid State 11 12th August 2005 02:20 PM
Copyright ©1999-2013 diyAudio
