L'Amp: A simple SIT Amp
Old 16th April 2012, 12:32 PM   #961
generg is offline generg  Germany
generg's Avatar
@juanitox
you really mean such a high source resistor of 2k5 -3k? It seems to high to me, or do you mean 2R5 and 3W? I must order such a big cap...
@Zen Mod what a fate......... ! Next life....?
@vdi_nenna it was a pleasure.....!
and the First Wtt is......a really First Class PSS Idea
Old 16th April 2012, 02:19 PM   #962
juanitox is offline juanitox  France
juanitox's Avatar
oups sorry , yes between 2.5 3ohm for sure , 15 watt to be between -5 / -4V between gate and source .. Epcos sikorel or Rifa ph200 works well here .. with your 10uf mkp.. for the source res i have put 2x 5ohm 12watts mills
French is not a crime.
Old 16th April 2012, 06:25 PM   #963
generg's Avatar
Juanitox one more question, when I take these source resistor and loose 4-5V for the negative bias, did you keep the 24V supply voltage Mike suggested or did you go for 29V to compensate the loss.......
Old 16th April 2012, 06:44 PM   #964
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by generg View Post
@Zen Mod what a fate......... ! Next life....?....
naah
I'm not complaining .....but opposite ....... I'm happy that finished "product" is less important than next prototype
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 16th April 2012, 06:59 PM   #965
juanitox's Avatar
yes i keep my 24V power supply so it turns with a 19V at 1.6 amp between drain and source , the 2SK82 run cooler like that but same power as the Res loading version..
Old 16th April 2012, 08:52 PM   #966
generg's Avatar
O.K. I understand, mon ami!
Les condensateurs sont ordonné.........
Encore un autre plaisir...... Je ne peux pas arrêter.....
Old 17th April 2012, 05:20 AM   #967
juanitox's Avatar
what a chance mon ami! i have finished moding my SIt amp , preamp and source ... what a boring life to have a system working fine ; hoping everyday something burn
Old 17th April 2012, 08:19 AM   #968
generg's Avatar
what a pity that we (sorry) are so stupid....
and have always to wait for Nelson, Mike and Aleksandar....
the three saints (for me).....
besides that I seem to have an build in mechanism the journey goes on, despite the praising words I am writing after finishing one project....
Old 19th April 2012, 09:23 PM   #969
generg's Avatar
Still waiting for the Rifa caps to try juanitox solution
I made some small experiments.....
I tried to get rid of my battery biasing by implementing a 4 Ohm thick film resistor in the negative rail, with the goal to adjust the current through Mikes Semisouth solution to 1,5A. I got by the resisor about 6V available biasing voltage. I took parallel to the resistor the 10k pot and two 15000uF caps Panasonic.
Because I was a bit afraid that it could take a too long time to fill the 30ooouF and to have meanwhile a Poof of the SIT I implemented first time the additional 10k and 220uF in the Semisouth positive biasing branch, I added to my last MU-follower idea I posted some time ago here.
And it works, the current comes a bit later to the full value than the biasing voltage!
Is it correct to see these 4 Ohm resistor in the negative rail as a kind of source resistor but bridged with a cap?
And is it correct that when you need for a 1 Ohm Resistor about 50.000-100000uF I need for 4 ohm only between 15.000 and 30.000uF?
The Semisouth solution B Mike suggested was a bit better in the highs and details and the depletion mode IXYS solution sounded a bit darker, maybe mor bass, less detailed to my ears.
I had more difficulties to dial in to 19V and 1,6A with the self biasing solution D than with the Semisouth solution B.
Because I used my First Watt PSU with two 2,2 Ohm Vishay thickfilm resistor in series I got
the voltage down to about 41V. So 19V at the output node is near to the half of the supply voltage.
And because all went fine I will again start to get a better impression of my MU-follower adjusting.
Once you have the Semisouth solution B from Mike it is very easy to make the small changes to get the MuFollower.
In my last experiments the mufollower sounded a bit to aggressive compared to the pure CCS..... But maybe I was not tricky enough the first time to get the Zen Pot working in the right way.
I will report and of course also report my experience with juanitox modded inductor solution.
Old 20th April 2012, 08:13 AM   #970
protos is offline protos  Greece
protos's Avatar
A simple schematic would help to see what you did.
So you have a proper positive and negative rail on your ps? Or is the negative the bias supply rail ? Is it rated for the power you want?
Is the gate referenced to ground or to the negative rail?
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´
Morgan Jones, Building Valve Amplifiers.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
