L'Amp: A simple SIT Amp - Page 92 - diyAudio
Old 5th April 2012, 10:38 PM   #911
ra7 is offline ra7  United States
Thanks for that summary generg.
Can you also summarize how that mu follower circuit works?
Old 5th April 2012, 10:39 PM   #912
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my fave Philips or ERO or ROE 10nF MKC as bypass ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 5th April 2012, 10:43 PM   #913
I have used claritycaps SA, nice! neutral with little warmish
I open a bit bypassed with small mundorf s/o , you can use a supreme or Vishay MKP1837
Old 5th April 2012, 11:07 PM   #914
Michael Rothacher's Avatar
Originally Posted by generg View Post
Have nice Easter Holidays Mike!
Same to you!
And, thanks for the capacitor info. I've been very tempted to try some fancy caps myself.
Old 5th April 2012, 11:36 PM   #915
Michael here nice guide Humble Homemade Hifi
and http://www.audiocircle.com/index.php?topic=54218.0
Old 6th April 2012, 06:52 AM   #916
juanitox's Avatar
Generg my no cap input is my fav with source resistor version .... but..... in absolute case i use Epcos MKTS ( very expensive on radiospare) or audiophilus Clarity cap ESA 250V ..
French is not a crime.
Old 6th April 2012, 08:14 AM   #917
generg is offline generg  Germany
generg's Avatar
Yes the most horrible moment is when you recognize that they sound all so different...!
The better moment is when you recognize that they all do some things good and some more bad and that you have the choice that is no choice......
And you tend to look at the components before and after that cap to be neutral, when you begin to realize how many of these components also have to consider you could get crazy by the permutations you have to test....and you begin to relax...
But back to the point really .........astonishing sound change by one cap.
Of course I will try to use "no" cap, the output cap of my UGS is Nelson like an 220uF bypassed by a 100nF MKC (hi ZM ), doing the job alone, I must only put away the 100k after the outputcap because it changes the bias voltage! To lower voltages, means higher current, means hotter SK82.
and the First Wtt is......a really First Class PSS Idea
Old 6th April 2012, 08:27 AM   #918
generg's Avatar
It behaves more complicated than the simple solution B Mike suggested (CCS with Semisouth)
To give an example, I trimmed the k2 dominant to K3 and the hissing sounds got too sharp. I thought that the sound should get more darker....
So I am still looking for the right mix.....
And when I want to relax after the desperate search I take the simple MIKE CCS because it sounds simply good.
So I cannot say up to now that the MU is better or much better than plain CCS...
Old 7th April 2012, 01:58 AM   #919
Anchan is offline Anchan  United States
Default Gain Question
Hello-
You guys are doing a great job with this thread. I really don't need another amplifier, but I am really tempted anyway. Perhaps someone can relate.
A few questions:
1) What is the gain of the Hammond Choke version? I thought I saw 6db somewhere, but cannot seem to find it again. The CCS version I believe is 8db.
2) If I wanted to add a simple preamp to this amp, how much voltage swing is OK on the gate of the 2SK82. 5-7 volts OK? I'd like to get a good 10-15V peak output to the speakers if possible. Is that possible with just a 24V supply as in the Hammond Choke version?
3) If I go with the CCS version of this amp, what are the thermal resistance heat sink requirements on the CCS transistor, as well as the 2SK transistor. It looks like Micheal was using a .3 C/W unit from Newark for the CCS, but what about on the 2SK? I'd like to trim down the size if possible. Would a .5C/W on each device be too small?
4) I know its heresy, but I was considering going switch mode on the PSU. Maybe something from here: http://connexelectronic.com? Maybe this: http://connexelectronic.com/product_...hkg7ut5plrird5
Thanks again.
Old 7th April 2012, 09:19 AM   #920
NYCOne is offline NYCOne  United States
I'm nearly ready to build. Do you have second thoughts about your Mu follow design? If you have K3 dominate K2 does it sound good?
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
Copyright ©1999-2017 diyAudio
