L'Amp: A simple SIT Amp
Old 26th March 2012, 06:41 PM   #821
generg is offline generg  Germany
generg's Avatar
ha, ha, thanks for the applause.....
but of cause I do not know why it is as it is.....
and I still do not know why Papa puts so many caps near to the Vishay resistors in SIT-1...... nobody any idea?
maybe he loves caps of tea?
and the First Wtt is......a really First Class PSS Idea
Old 26th March 2012, 06:45 PM   #822
ra7 is offline ra7  United States
Could it be the output cap?
Old 26th March 2012, 06:48 PM   #823
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Well then, how does it sound to R100 only amp?
Old 26th March 2012, 06:57 PM   #824
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
convenient place for mucho PSU caps (and possibly just few output ones) - sounds logicall ?
2 reasons for that - poor PSRR of circuit itself , empty pcb if you leave just resistors there
edited - few important words swallowed , probably .... usual ZM's brainfart
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 26th March 2012, 07:54 PM   #825
generg's Avatar
yes Zen Mod and ra7,
that is the most logical and simplest answer.....
and I do not see CRC in the PSU so more caps are useful....!
but my intention is not to discuss Papas SIT here primarily, I was more interested if the picture gives us an advice to "better" our thick film resistor solution......sounding not so dark....I repeat, I understand now the people doing "Bulb Rolling" on the search of the right sound mixture....
but I confess...... I am always looking at the pictures of Papas Amps at 6moons like a junkie....on the search of hidden riddles and treasures....I confess...
Old 26th March 2012, 08:00 PM   #826
generg's Avatar
I try to accustom myself to to the sound.....
Old 27th March 2012, 10:43 AM   #827
protos is offline protos  Greece
protos's Avatar
Originally Posted by Michael Rothacher View Post
Yes, the 47K. I've seen SITs with 100uA or more gate leakage current. With 100uA, you'd be dropping 4.7V across a 47K resistor. It's worth a look anyway. Being aware of it is half the solution.
I did check with some and yes the one with 11.5 vgs had a high leakage that accelerated once the sit reached a certain temp. With a 12k there was almost none.However the variation, testing with the 12 k now, is still very wide as I described so no real change there although it seems now the two sits with the highest vgs are more closely matched now with the 12 k. So out of 8 sits I have about three pairs that seem reasonably matched.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´
Morgan Jones, Building Valve Amplifiers.
Old 27th March 2012, 10:58 AM   #828
DUC985 is offline DUC985  Germany
if i look into all current sources, i would like to understand how the voltage drop within mosfet is calculated ? In the latest example we have the R100 at the drain 35V and at the SK82 19V and want around 1.6 current flowing.
So whats the math behind all that ..
Old 27th March 2012, 11:53 AM   #829
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Good work, protos.
It's very temperature dependent, so you may find things will behave a little better still once they're gooped-up and bolted to a big heatsink. You'll have to use the negative bias supply version to generate the correct bias voltage. You could also do as Generg does and use a battery and pot for testing. You just have to be careful the battery doesn't drain and cause a meltdown.
Old 27th March 2012, 04:11 PM   #830
Skorpio is offline Skorpio  Denmark
One of the power resistors might be PSU series R...
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
