L'Amp: A simple SIT Amp - Page 63 - diyAudio
Old 7th February 2012, 12:02 PM   #621
AudioMaker.Tech
Michael Rothacher's Avatar
Real speakers aren't resistors and have a rising impedance at low frequency. I would not necessarily interpret the graph as meaning "worse bass". Have a look at some THD vs. Frequency graphs for pricey 300B amps.
With 101dB speakers you're probably fine as is. It's all up to you.
For those considering various iron-core inductors, this amplifier uses an air-core inductor to avoid saturation.
Visit AudioMaker.Tech
Old 7th February 2012, 12:13 PM   #622
AudioMaker.Tech
Originally Posted by Chris Goldring View Post
How will that affect the output impedance?
The output impedance is around 8 Ohms.
Old 7th February 2012, 04:39 PM   #623
juanitox's Avatar
lundhal has a 100mh C Core filament choke 3,4A (5,4 A saturation) , do you think it could fit the sit?
French is not a crime.
Old 7th February 2012, 04:44 PM   #624
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by Michael Rothacher View Post
....... I'm going to read over that tonight.
so - any comment ...... or plan ?
you can try that with any proper mosfet , too ..... or smaller SIT
plain SE , parafeed , whatever .....
edit: shade-ed mosfet , too
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th February 2012, 04:47 PM   #625
AudioMaker.Tech
Aren't you the guy who doesn't want to use an inductor?
Post a part number.
Old 7th February 2012, 04:51 PM   #626
juanitox's Avatar
i'm the guy who wants to play alone in his garage far for a screaming family
the lundahl 100mh 3,4a is the LL2733
Old 7th February 2012, 04:52 PM   #627
AudioMaker.Tech
Originally Posted by Zen Mod View Post
so - any comment ...... or plan?
I knew I forgot to do something. I'll will check it out tonight.
Tell NP not to post F5 Turbo and distract me.
Old 7th February 2012, 04:57 PM   #628
flg is offline flg  United States
flg's Avatar
Originally Posted by flg View Post
...Some time back I played with the ZenV9 circuit using a big Hammond choke load instead of Aleph. Actually, I think it worked quite well. But, 1 thing that it did do that is somewhat of a problem is it made physical, vibrational noise with signal. It was a frequency/amplitude sesitive thing (maybe started around 3k?) but, quite audible. I believe they were spec'd well enough for this amp (3-5A, .64 ohm, 100+mH IIR)
You might never notice this phenomina unless you test with a resistor load. Have you noticed this problem? Can you hear your amp without any speakers?
I don't know if it's the E-Core Lams or the windings or? I wonder if impregnating epoxy resin into the windings will stop this or?...
Yea, that was a 5A PSU choke in the 195 series, I believe, w.64ohm DCR. I was probably doing 1.5-3A Iq. The trouble is the liniarity of the core. It is "metal" lams and it needs to be alloy bla bla or somethjing else designed for higher freq.s than 60Hz? And, empregnated with High tech resin stuff!
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 7th February 2012, 05:02 PM   #629
AudioMaker.Tech
Looks way too small to me. I would expect a suitable iron-core to be a serious hunk of metal.
Old 7th February 2012, 05:07 PM   #630
Zen Mod's Avatar
do not worry 'bout that
go back in a day or two , for more waiting
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
