L'Amp: A simple SIT Amp - Page 60 - diyAudio
Old 3rd February 2012, 04:55 PM   #591
ra7 is offline ra7  United States
Ok... so, if you change the source resistor, the amount of current flowing through it will change, correct? It just happens that a 1 ohm resistor is about where we want to be in terms of current draw.
Old 3rd February 2012, 04:57 PM   #592
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by ra7 View Post
...It just happens that a 1 ohm resistor is about where we want to be in terms of current draw.
that's too much of coincidence , if you ask me
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 3rd February 2012, 05:11 PM   #593
juanitox @the R-core is hot ? your suggention is for 2x500VA or the 2x300VA is sufficient ?
Humm I have only one 500VA 30Vac...
Tnx
Old 3rd February 2012, 05:11 PM   #594
flg is offline flg  United States
flg's Avatar
When I was experimenting with ZV9, with a choke load, there was this other interesting enthusiast we havent seen much of lately. Maybe some of you have not seen before "The Donut". I'm not sure what to call it? If you know Magura, you know:-) If this is new to you???
ZM!, what is it I want to send them to. A monster differential choke loaded donut borrowing from ZV6, 7 & 9?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 3rd February 2012, 05:11 PM   #595
hahaha... yes. Thanks ZM!
Old 3rd February 2012, 05:28 PM   #596
Zen Mod's Avatar
Originally Posted by flg View Post
ermmm ... and what is a question ( pardone moi , non native English writer ) ?
..... A monster differential choke loaded donut borrowing from ZV6, 7 & 9?
nope ...... Donut is completely original , never seen before , best thing after bread
Old 3rd February 2012, 05:30 PM   #597
juanitox's Avatar
Tnx
no the 300VA R-core stay cold , no problem on that side
French is not a crime.
Old 3rd February 2012, 05:39 PM   #598
flg's Avatar
O.K. but it's not something like a Qspeed Cascoded diff-amp with choke load( combination ZenV7 and ZenV9?)
But it is choke loaded. With Magura chokes!
Old 3rd February 2012, 05:42 PM   #599
AudioMaker.Tech
Michael Rothacher's Avatar
Q. What controls the amount of current through the CCS? Is it the bias voltage on the SIT or the Vgs of the IXTH? Or both?
It does feel a bit "chicken or the egg" doesn't it?
As ZM points out, the MOSFET is self-biased, and we're using the adjustable voltage reference to balance the currents and put the SIT drain where it needs to be. You could use a slightly smaller source resistor and run with higher current, but I found that wasn't really necessary as it didn't have a big impact on performance. Also, the bigger source resistance helps stabilize the CCS a bit. I included a spot for RTRIM, a trimming resistor, in the drawing in case you want to really fine tune things.
Visit AudioMaker.Tech
Old 3rd February 2012, 05:55 PM   #600
flg's Avatar
Originally Posted by Michael Rothacher View Post
This is not an issue with a big, heavy ga. air-core.
Iron is another matter, though.
Be sure to grab that pdf when you get home.
Well bud, so far I guess I know why you said that. I can all but guess the vailues on the Iyxs CCs with what, a TL or other bias idea in mu folower???
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
