L'Amp: A simple SIT Amp
Old 25th January 2012, 08:08 PM   #501
Roscoe Primrose is offline Roscoe Primrose  United States
Heck, with the bulbs, it's 600W worth
The more of them you run, the hotter the heat sink can safely be... Also, the heat sinks I'm planning to use are large, but not very thick, having more resistors will make it easier to spread the heat out on the sinks.
Besides, they're cheap, and non-inductive, so how can you go wrong?
Roscoe
Old 25th January 2012, 08:35 PM   #502
ra7 is offline ra7  United States
What's wrong with bulbs? They're cheap, don't need a heatsink and, as a bonus, give light.
Sure, some resistor-based solution might sound better, but really, the amount of heatsinking required will be ridiculous.
Old 25th January 2012, 08:36 PM   #503
nicoch58 is offline nicoch58  Europe
with resistor ,we have a lot of heat ...I thinks is better use a fan, like Noctua....
or lamp from US
Old 25th January 2012, 08:41 PM   #504
Bulbs are huge, and fragile.
Maybe we don't want the light.
Heat sink size isn't that bad since the resistors can safely operate at much higher temperatures than the JFets....
Roscoe
Old 26th January 2012, 05:01 AM   #505
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Default Option....
Originally Posted by Roscoe Primrose View Post
I plan to use 4 of these in parallel per channel: MP9100-50.0-1% Caddock Thick Film Resistors - Through Hole
Roscoe
Hi Roscoe!
I found Caddock: Power resistor 20 Ω 100 W here at my delivery!
Two of the in paralell gives 10 ohm and then you take 2 pc 2ohm/50 watt to give you 300 watt with 14 ohm.
Or something like this which will keep cost somewhat lower - and the heat acceptable???
Best
Olav
Old 26th January 2012, 05:31 AM   #506
juanitox is offline juanitox  France
juanitox's Avatar
sure you re right but bulbs are not a good idea with a daughter playing football in the living room
French is not a crime.
Old 26th January 2012, 05:36 AM   #507
juanitox's Avatar
Originally Posted by OlavHaal View Post
Hi Roscoe!
Best
Olav
not a good idea you will have 35 watt dissipation on a 50 watt resistor , too short , try to find minimum of 100W or use 4 20 ohm , remember i use 1 800W 10 ohm resistor and my heatsink is still very hot with 75W off dissipation on it
Old 26th January 2012, 06:18 AM   #508
OlavHaal's Avatar
Hi Juanitox!
Yea - I know very well - but with 2 in parallell = 2x 100= 200 watt plus 2 50 watt (or make it 100 watt) = 200 + 100(or 200)= 300watt (or400watt).
So you get really close with this - I believe.
Have to run - my helicopters to shore will leave soon
Olav
Old 26th January 2012, 08:13 AM   #509
generg is offline generg  Germany
generg's Avatar
Hi Juanitox!
Olav
I have a case for the F5 or F4 with adequate heatsinks and these are sufficient for the SK and the resistors.
Olaf I think your values are o.k. regarding the heat, I have the same wattage combined, only difference, I used four 10 Ohm/50W to make the ten Ohm as a starting point for the resistor chain.... so the heat is still a bit more diversified...
but I do not think this is necessary....
Juanitox is your machine ready and sounds.....?
and the First Wtt is......a really First Class PSS Idea
Old 26th January 2012, 08:17 AM   #510
juanitox's Avatar
i 'm finishing mounting the Rifa and power choke , and R-core transfo in my little chassis ... it will sounds or not this weekend
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
