L'Amp: A simple SIT Amp
Old 23rd January 2012, 08:39 PM   #481
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
ZM knows Station
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 25th January 2012, 07:37 AM   #482
generg is offline generg  Germany
generg's Avatar
O.k. guys,
I played the last days with the SIT in a MUfollower constellation.....
It was very interesting to play with the output node......
Output at the drain of SIT, between the resistors, at the source of the upper Semisouth...
Most bass for my Tone Tubbies came from the last possibility, overall clearest sound from the first possibility....
The MU allows to adapt the sound more to the chain or to the speakers.
But, I repeat ....... Overall clearest sound is still the thick film resistor solution......(I did not try bulbs)
Maybe the wattage or grip for my Tone Tubbies is a bit weak....there the MU gives more power.
and the First Wtt is......a really First Class PSS Idea
Old 25th January 2012, 07:58 AM   #483
serengetiplains is offline serengetiplains  Canada
serengetiplains's Avatar
That's my sense of this audio stuff, generg. What actually really distorts the musical signal is everything that electrically codifies and processes that signal. The less of that stuff in play, the obviously empirically the better. I mean, you don't cascade five transformers into the middle of your design only because you can. And where an alternative between passive and active exists, the passive probably got the edge.
Old 25th January 2012, 08:08 AM   #484
Zen Mod's Avatar
Originally Posted by serengetiplains View Post
.....cascade five transformers into the middle of your design only because you can......
is there anything wrong with that ?
Old 25th January 2012, 08:24 AM   #485
generg's Avatar
...... I mean, you don't cascade five transformers into the middle of your design only because you can. ....
why not "transform five cascades in the middle of design.....".
for people like me without much knowledge and much eagerness it is often the the logical solution...
thanks for your comment!
Old 25th January 2012, 08:57 AM   #486
Zen Mod's Avatar
Originally Posted by generg View Post
O.k. guys,
resistors vs. plain CCS vs. Mu (out from SIT drain ) , speaking strictly about Lowther part of presentation ?
than Varislope included in Mu ....
Old 25th January 2012, 09:32 AM   #487
juanitox is offline juanitox  France
juanitox's Avatar
for the ones who have PSUD and knows how to use it
i have 22000uf 0.01 ohm / and 47000uF 0.01 ohm with a 10mh hammond choke between . what is the best config , 22000 or 47000 first cap ?
French is not a crime.
Old 25th January 2012, 10:54 AM   #488
nicoch58 is offline nicoch58  Europe
generally low first
Old 25th January 2012, 10:58 AM   #489
PSUD little guide
http://basaudio.net/pubs/dhtrob_psu.pdf
Old 25th January 2012, 12:35 PM   #490
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Default generg........??
Hi Generg!
Is these the kind you used: Vishay Power Thick Film 2 Ohm Resistors(25watt)
or is there others that is easier and with higher watt pr. resistor?
Best
Olav
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
