L'Amp: A simple SIT Amp
Old 13th January 2012, 08:37 AM   #371
crt is offline crt  Indonesia
crt's Avatar
@ Chris
more image please ?
looks gorgeous
Old 13th January 2012, 08:37 AM   #372
generg is offline generg  Germany
generg's Avatar
Hi Chris, would be happy if my prototypes would look like this....
I will start with the second channel today and try again in direct comparison the Mufollower and all the CCSs Salas suggested....
the last try with the Mu was a bit unfavorable , I choked the upper SemiS by only implementing the bias network but no 47k to prevent the signal going the sides away....
So repetition is matter of honor...
and the First Wtt is......a really First Class PSS Idea
Old 13th January 2012, 08:46 AM   #373
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Default Seems interr.....
Originally Posted by Chris Goldring View Post
Hope everyone have a great time, i certainly do!
The prototype amp is now done and works very fine indeed.. I'm running it at 32V and about 1.6-1.7a (each channel), i think the heat sinks are good enough for that as they "only" get to about ~50C..And the resistors? a whopping ~150C at current power
The sound is awesome, the sweetness, the speed, the NUANCES, the big SPACE between the notes are just nothing but amazing.. It's just that, the timeless and sweet feeling and almost infinite space between the notes Is sure has that "sitting up all night" quality to it too. I can't wait to get some more proper cooling and push the power a little..
A tip might be to use a BJT based cap-multiplier in the PSU, just a thought.. I use it total hum-free with a total of 15,000uF for both channels as i don't like amps running something like 80,000uF+ (sounds slow with dull nuances if you ask me)
Hi Chris!
Your solution seems like a "easier" solution - with not so high voltage and smaller caps! The big heat sinks that is req is ok - but the somewhat smaller size on the the PSU is more to my liking.
I have not yet decided how to build my LÀmp - so my SK82 is still waiting for a "sound" solution. Whatever that means?
So Chris - will you provide some info, schematic how your amp is - when it is more or less finished? And what speakers you are driving your version with?
Will be VERY grateful for an answer( and my B1 - that is soon to be finished) will be a happy partner - somewhere in time!
Greatings to all.
Olav
Old 13th January 2012, 12:24 PM   #374
Chris Goldring is offline Chris Goldring
Chris Goldring's Avatar
Originally Posted by OlavHaal View Post
Hi Chris!
Greatings to all.
Olav
Hello,
My PSU is super simple using just a single 2n3055 BJT. i made a simple schematic too
at the moment i'm only using one single PSU as in the schematic (except i use discrete diodes instead of the bridge)
I might make a schematic for the amp too if anyone really want that
I'm using a couple von schweikert VR2 at the moment, have no trouble with insufficient volume levels, and that is at 32V supply
When i get more serious with my heat sink i probably will make a 45-50V PSU with another gyrator/cap-multiplier, using one or two "transformers+rectifiers+first-cap"
And Thank Michael for making the Great article about this project, super-fun read indeed!
Old 13th January 2012, 12:58 PM   #375
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Beautiful construction, Chris.
I know you'll be really pleased with the higher power. And, remember you can play with the harmonic seasoning by adjusting the bias ever so slightly in either direction.
I'm glad you're having fun
Visit AudioMaker.Tech
Old 14th January 2012, 12:45 AM   #376
AudioMaker.Tech
...I'm running it at 32V and about 1.6-1.7a...
That sounds just about right. With a 32V supply, 12 Ohm drain load, 8 Ohm speaker, Vds = 12V, Id=1.62A I see .4% THD @ 1W. I'd call it a 2.5-3 Watt amp. At 2.5W, we're at around 1.35% THD. I'd say you've got it dialed-in pretty well, now you can fine tune it to taste.
Old 14th January 2012, 10:25 AM   #377
I wish i had a THD analyzer (or even better, a spectrum analyzer) too, would be great fun. I might work on some fine tuning later on, but not too sure that it would do much good without measuring the THD/spectrum.
I get quite nice level of volume with 1-1.5V RMS input and using it directly with the outputs from my DAC, no volume control or preamp for uttermost purity
Would you or anyone else using (BIG)C+R+(BIG)C PSU consider building the one i use at the moment and compare the different sound? Would be fun to see if we get at the same results
PS: I might add that i use 1000uF located in the amp for each channel and running a power cord for each channel to the PSU.
I was thinking how i was going to construct the more final version, dual mono block or a separate PSU+amp.. I am leaning towards the later with or without true dual PSU..
Old 14th January 2012, 01:07 PM   #378
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Sure, I think you should post your current and final designs for power supply, and the amplifier schematic as well.
Most Salas Boards In stock, Private Message | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Available, PM
Old 14th January 2012, 01:37 PM   #379
AudioMaker.Tech
I just use the meter to get in the "zone".
The fine tuning is all up to your ear-brain interface and it often will not be the extreme null spot.
Old 14th January 2012, 05:42 PM   #380
juanitox is offline juanitox  France
juanitox's Avatar
YEEPEEEEEEEE YEAHHHHHHHH , wonderfull , merveilleux ,c'est Formidable!!!!
my SIT is on fire, 17V , 2,77 amp a BIG sound a little hum with my 102db horn speaker. but definitly too much gain with my threshold SL10 , i make a mistake not too buy a BC1 ..
pics to come...
for the hum do you have a resistor between hot and ground of the input RCA ?
French is not a crime.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
