L'Amp: A simple SIT Amp
Old 5th March 2018, 07:10 PM   #2901
atmasphere is offline atmasphere  United States
atmasphere's Avatar
If you use an effective CCS you may find that equalizing the currents through the differential amplifier is not needed.
I usually use a pair of devices wired in series, with the top gate referenced to ground via a zener diode, and the bottom gate tied to -V with the source. A biasing resistor is needed for the zener diode, and a second biasing resistor in the source circuit of the bottom device to set the current.
You should see measurably better bandwidth, lower distortion and greater gain with this setup.
Old 6th March 2018, 12:19 PM   #2902
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Great. Thank you.
A very fast CCS is needed, so cascoded be it.
The good thing about resistors is that they do not have a slew to worry about...or am I wrong?
Old 6th March 2018, 01:02 PM   #2903
maxlorenz's Avatar
Already studying CCS's (source/sink) like mad.
I'll probably also replace the big R for the VFET with a good one soon.
More rejection and more power with one move. We'll see if the "electronic microscope" effect is retained or lost with that mod...
Old 1st May 2018, 09:17 AM   #2904
qwertyl is offline qwertyl  United Kingdom
I have 2 spare 400VA transformers, but they are 2 x 22VAC, not 18VAC. Can I still use them to build 193V version? Any adjustments need to be made to the original schematic?
Old 2nd May 2018, 04:10 PM   #2905
plasnu is offline plasnu  United States
Easiest way to drop the voltage would be adding a few more resistors at CRC filter.
Old 2nd May 2018, 04:26 PM   #2906
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
4V more is nothing to worry about
just set output node higher, accordingly
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd May 2018, 06:34 PM   #2907
What do you mean? Should I set bias a bit lower than 2A?
I suppose I can always drop a couple of volts by adding another RC in power supply filter...
Old 2nd May 2018, 08:34 PM   #2908
Zen Mod's Avatar
output node means point where output cap is connected ...... I'm pointing on drain voltage practically
you have more than enough info in thread , regarding Iq and output node voltage
what I was saying is - go ahead with your xformers , rail voltage isn't carved in stone
Old 3rd May 2018, 07:25 AM   #2909
Ok, thanks. I will do a bit more digging
Old 8th May 2018, 10:02 AM   #2910
sontero is offline sontero  Italy
Originally Posted by maxlorenz View Post
Dear all,
L' Amp style amps, while being wonderful, may be seen (at least I see) as starting points in the learning experience and I cannot avoid wondering about many experiments to be done, like CCS, cascoded CCS, cascoded VFET, which are some of the steps to add to my already modded amp.
I have been using my Tokin amp with a differential amplifier for the input and it really improved a lot.
As some may know, I am experimenting with Peufeu's recommendations for diminishing (putative) thermal memory distortion effects, like the cascoded-CFP input pair. Well, yesterday I replaced the input pair differential with a "cascoded-compound CFP" pair of units, using Toshiba's SK170 as both, the cascodying element and as the "driver" of the CFP pair and a BC560 PNP as the "emitter follower" of the pair, with a 1K resistance on its emitter. I confess I studied some academic articles about this compound Szicklai but they were too much for me, so I took the plunge as the good Lord seemed to advice me...and it worked!
First listening tests are very encouraging.
I attach picture of the cascode-compound CFP units and a diagram of the target amp...
I hope you like it.
M.
Hi Max
Also me have a pair of sk180 as a soon experiment with l'Amp.
For now i have build a pair of MoFo monoblock....very great amplifier.
Waths is the gain of your interesting CFP?
Waths bias have the sk180 for 50v B+?
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
