Old 10th January 2012, 07:35 PM   #281
generg is offline generg  Germany
generg's Avatar
thank you very much, BTW for asking.....bulb rolling, he,he sounds good....!
and the First Wtt is......a really First Class PSS Idea !
Old 10th January 2012, 07:42 PM   #282
generg's Avatar
Originally Posted by Salas View Post
That's what I found in Wikipedia about that phrase:
steely-eyed missile man
English
1. (US, slang) A NASA astronaut or engineer who quickly devises an ingenious solution to a tough problem while under extreme pressure.
Hi Salas,
perfect, that is exactly the way I feel the last two years when I retired and started to work with the Pass "Apollo" Forum.....every year two or three new rockets (F5 turbo, F6, SIT, M2, J2....) published by the Amp committee in Foresthill.
I reflect to change to the Russian side maybe there is less stress and more vodka.....
Old 10th January 2012, 07:44 PM   #283
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, switch to Energiya rockets!
Old 11th January 2012, 10:11 AM   #284
generg's Avatar
O.k. The SIT with the four 3,3 ohm resistors is the best!
NO doubt! All shyness is gone! Precise, powerfully til the bottom. With my quick B1 now a bit bit too sharp wit my Lowthers.
Maybe for Lowthers characteristic I preferred in the past darker sounding amps.....
What a change! Of course I will look for the distortion spectrum, maybe I have dominant k3....
Unfortunately I have now a good hum, is it possible that the placing of the resistorloop in the case nearer to the xformer is hum susceptible? I suppose so... Because I put away the second channel, crippled F4, to lower the current and the hum remained on the same level.
Mike you are right to persist on the try with the bulbs or resistors, they set the level for other solutions like CCS or Mufollower!
Salas please another CCS, still better than the last....
Best Gerd
Old 11th January 2012, 10:27 AM   #285
Salas's Avatar
See solving the hum issue first, if the hum won't go no matter what resistor loop care, its about PSU breakthrough including its higher harmonics. That cascode CCS gives great PSRR up very high, I could present you a single Mosfet one with a TO-220 having a faster gate for mid way results you may prefer, and less components, but try solve the issues when using a resistor first, since you gravitate towards that one. And let me know.
Old 11th January 2012, 10:30 AM   #286
Franz Gysi's Avatar
Gerd
You are using for resistors in series, right?
What wattage did you choose?
Franz
Old 11th January 2012, 11:05 AM   #287
generg's Avatar
Hi Salas, thanks!
yes I will look for the hum by placing the resistors in other way....
the bulbs have a good place on the top of the case, less hum.
o-k- with your CCS the hum was really absent...
I am still not happy with so much wattage in resistors......
so I am open to try another CCS solution, really!
" its about PSU breakthrough including its higher harmonics." What do you mean by this? I use an 500W xformer and the normal First Watt pcb with 8x22.000uF, not sufficient? even for one channel? of course I combined the two +-24V to 48V.
hi Franz,
I used three 3,3 and some 1,5 and 1 Ohm Vishay metal combined, I got them here
50 Watt, axial bei reichelt elektronik
I suppose this non inductive Vishay should be better......?
RTO 50F 10 - Dickschichtwiderstand 50W TO220 10 Ohm, 5 - Dickschichtwiderstände TO220 bei reichelt elektronik
Old 11th January 2012, 11:12 AM   #288
Salas's Avatar
I wrote IF its not due to loop hum then its about PSU breakthrough. Don't be surprised if there might be charging cycle products in heavy PSUs also. Very low impedance goal in such PSU is another thing. SE power stage has no cancellation like PUSH-PULL, plus some gain here. Remains to find out if its due to loop sensitivity for transformer field. I will see about another CCS for you to try soon enough then.
Old 11th January 2012, 11:40 AM   #289
www.audiohobby.com
All my copies are fairly quiet.
Part Deux has around 30uV of noise.
Old 11th January 2012, 11:49 AM   #290
www.audiohobby.com
Hello Gerd,
I'm glad you tried it. Are your Lowthers 16 Ohms? What is the supply voltage?
I'll have some data and info on various CCS's later, after Part Deux comes out and I finish my current project. But, by all means, full speed ahead.
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 20 2nd March 2013 08:26 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
