L'Amp: A simple SIT Amp
Old 17th October 2013, 09:35 AM   #1911
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
calculate
max output swing is ....
or - even better and easier - L'Amp is hawing how much Watts at output at 8R ...
then divide that power with Rbleed/8R ratio
(put 3W in case of 150-220R)
(or put 3 x 1K plain metal films in parallel and chill ).........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 17th October 2013, 11:28 AM   #1912
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
The amp ideally shouldn't be turned on and off without a speaker connected anyway. The schematic includes an 8 ohm load at the output.
When you try to measure DC at the output without a speaker and or bleeder resistor connected, you are measuring the voltage on the cap which is discharging through the 1M resistance of your meter, and that will take a long, long time to reach zero.
I've mentioned all of this before here, and a note has been added to both articles.
Visit AudioMaker.Tech
Old 17th October 2013, 08:39 PM   #1913
vdi_nenna is online now vdi_nenna  United States
vdi_nenna's Avatar
L'Amp: A simple SIT Amp Send a message via Yahoo to vdi_nenna
Ok. I'm sorry.
I build, therefore I am.
Old 17th October 2013, 09:23 PM   #1914
AudioMaker.Tech
No worries. I just wanted to explain why you were seeing what you were seeing and take some of the mystery out.
Old 21st October 2013, 01:52 AM   #1915
vdi_nenna's Avatar
I have a standard Panasonic 15k cap at the output. I'd like to by-pass the cap.
I looked at couple of similar topologies (Zen 4 and Zen 9) and it appears to be OK to proceed.
Anyone try by-passing the output cap? What did you use?
Old 23rd October 2013, 01:39 AM   #1916
drjbf1 is offline drjbf1  New Zealand
drjbf1's Avatar
Does anyone know the output impedance of the CCS version?
Why finish an audio project when you can start a new one?
Old 23rd October 2013, 04:45 PM   #1917
AudioMaker.Tech
If memory serves (and it may not) it was somewhere around 4 ohms.
Old 30th October 2013, 03:54 PM   #1918
OllBoll is offline OllBoll  Sweden
I just looked at the ironamp which caught my interest...
I have a balanced source so I have a 10k/10k Jensen JT-11P-1 and so I wonder if I should put it in front of the simple sit as planned, or if it would be better to do the Ironamp frontend and skip the input cap, R1 and R2.
Old 31st October 2013, 01:12 AM   #1919
AudioMaker.Tech
Should work Easy enough to try. Mind your wiring. You might need the damping network. What say the group?
Old 31st October 2013, 06:12 AM   #1920
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Have you tried this baby with an Aleph current source?
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
