L'Amp: A simple SIT Amp
Old 16th September 2013, 11:53 PM   #1831
OllBoll is offline OllBoll  Sweden
Thoughts about amplifier gain:
If I've understood correctly in theory the gain of the amp is ( current source in parallel with speaker ) / ( 1/0.4 )
And it is because of this that gain increases with the inductor since the inductor has much higher resistance? Though not massively since the 8 ohm speaker still limits the gain.
So if we simplify and assume that the inductor has a resistance of 100 since we won't use the amp for bass the gain with an 8 ohm speaker would be close to 3 or 9.6 dB if I remember my math correctly.
But that is not what I wonder... what I wonder is that does this mean that if I use an 18 ohm speaker instead the gain jumps up to 6.1, or 15.6 dB?
Old 17th September 2013, 12:00 AM   #1832
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
choke means inductive storage
think twice output voltage , comparing to PSU
meaning - when having resistive or CCS based load part of amp , output voltage amplitude can go just between rails
when having choke - it can go almost twice that
roughly
voltage , same as ground , is elastic term
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th September 2013, 07:46 PM   #1833
bluewater is offline bluewater  United States
Originally Posted by Michael Rothacher View Post
The input cap is there in Figure 11 in case your SIT has enough gate leakage current to drop some voltage across the input. If you measure the input, and it is at 0V, then perhaps you can go without.
Hi Michael,
I was wondering how to test for gate leakage of your final circuit for the inductor version. If the input cap needs to be there what is the lowest value it could be without affecting circuit if possible.
Thanks,
Eric
Old 18th September 2013, 07:55 PM   #1834
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
You could measure the voltage across Rin (R1) and figure the current. Most of my 2SK82 examples have been a couple of microamps or less.
Does you preamp have AC-coupled outputs?
Visit AudioMaker.Tech
Old 18th September 2013, 09:15 PM   #1835
Hi Michael,
At the moment it is the LightSpeed but eventually I will be using the my B1 which is AC coupled. Oh! I think I see what your getting at. So I won't need the input caps for the L'Amp if my preamp has AC coupled outputs.
Old 18th September 2013, 09:29 PM   #1836
AudioMaker.Tech
Perhaps you won't. Try it. But you'll need a cap in the chain somewhere since the input will not be sitting at or near 0V in that particular case.
Old 19th September 2013, 02:46 PM   #1837
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
L'Amp: A simple SIT Amp Send a message via Yahoo to vdi_nenna
Any objections to using a pair of CL-30s on the primarys to protect againt in-rush current? Using seperate transformers for main circuit power and bias circuit.
thanks
Vince
I build, therefore I am.
Old 19th September 2013, 09:09 PM   #1838
AudioMaker.Tech
No objections spring to mind.
Old 4th October 2013, 12:52 PM   #1839
DIYspaceW is offline DIYspaceW  Slovenia
Here is my SIT Parafeed hybrid power amp manifested in matter.
There are two monoblocks...
Old 4th October 2013, 02:11 PM   #1840
Zen Mod's Avatar
more porn , please ..... schm included
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
