L'Amp: A simple SIT Amp
Old 10th September 2013, 12:46 PM   #1821
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
L'Amp: A simple SIT Amp Send a message via Yahoo to vdi_nenna
Here's a mono-block of the L'amp v193. It's in the "lay-out" phase.
I'm still on the fence regarding using the heat sink pictured.
I build, therefore I am.
Old 10th September 2013, 01:02 PM   #1822
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
It does look a little small, unless it's an optical illusion thing.
Visit AudioMaker.Tech
Old 10th September 2013, 01:18 PM   #1823
Antoinel is offline Antoinel  United States
Originally Posted by Michael Rothacher View Post
Anyone willing to loan me a thermal camera?
A regular camera will image it in the dark
Old 10th September 2013, 01:36 PM   #1824
vdi_nenna's Avatar
It sort of is an illusion because it's at an angle, plus the depth.
Anyway, it's at least as big or bigger than the heat sink on post #69.
It is machined for TO-03.
Old 10th September 2013, 02:09 PM   #1825
vdi_nenna's Avatar
I take that back. I'm not sure if it is bigger. Might have to track down a bigger sink.
Old 10th September 2013, 05:12 PM   #1826
AudioMaker.Tech
I just found out that participating Home Depot stores rent FLIR cameras, so I'll give that a try later. Thanks for the info.
Old 10th September 2013, 05:37 PM   #1827
Back from the gulf. No turtles, but I got to swim among a large school of "devil" manta rays.
Here's an opened 2SK82. 2 x 4mm dies. $25 for science.
Does open up unusual possibilites to cool the device .
  • Fashion dry ice into 1 inch circular pillars to fit in the open well and contact the base.
  • Drip de-ionized and distilled water in the well at a certain rate to a stable level without its overflow.
Old 10th September 2013, 05:46 PM   #1828
vdi_nenna's Avatar
That's good to know for a lot a reasons.
Insulting attic spaces soon.
Old 10th September 2013, 06:36 PM   #1829
flg is offline flg  United States
flg's Avatar
Just in the case you are not familiar with these things, imaging shiny metal objects like 2sk82s, 28s or whatever gives improper temp readings due to low emisivity. Looking at TO3P (plastic) packages is 97% correct but shinny metal will need to be coated with something to get correct temp readings. I used to use white out correction fluid but, I've been using Cerameque thermal compund lately. It's basically that you get reflectivity from the shinny surface instead of emisivity. Generally you will see black or low temp indications on something you know is hot if you've got this problem. You can even get reflected emisive energy from a shinny object. Different surfaces have a different emisivity. You can probably google and find a chart, I couldn't find mine. Shinny metal is the worst offender
Don't forget to post pics here.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 10th September 2013, 06:39 PM   #1830
AudioMaker.Tech
Good advice. Thank you, I'll try that.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
