L'Amp: A simple SIT Amp - Page 172 - diyAudio
Old 30th June 2013, 02:13 PM   #1711
juanitox's Avatar
Originally Posted by KASUMI View Post
Interesting juanitox ,where did you manage to get the PEH200's ?
The PEH169 also looks good
radiospare UK
French is not a crime.
Old 30th June 2013, 03:33 PM   #1712
Thank you KASUMI, I thought it would be an easier way...
Old 4th July 2013, 07:32 PM   #1713
Today I put the SIT on test......
The drain is 72V and the gate -12V, I am pulling 0.8A
So the dissopation is around 50W...
Everything looks good...only concern is the 50W rehostat which
is very very hot but it burns only 9.6W...
I am still waiting for the caps to arrive...
Old 5th July 2013, 06:23 AM   #1714
OlavHaal's Avatar
Red face Bypassed Source Res??
Originally Posted by juanitox View Post
in fact with a SS preamp i prefer bypassed source resistor version and with a tube preamp with output coupling cap i can go with battery on source which i prefer to LM317 bias module.. but anyway this sit is a keeper .
potting the 193V is a cheap but fine upgrade
Hi Juanitox!
I tried the solution with the bypassed Source resistor - where I used a 10volt/0.22 Farad Nec capacitor. At the same time I changed the 47 ohm Gate resistor to a Amtrans(earlier it was Metal Film). And the soundstage grew somewhat bigger and a little more clear - BUT the voices and the music grew much too sharp, edgy and tonally very unpleasant. Nearly as sharp as when I tried a relatively middlepriced loudspeaker-cable.
I also use Amtrans in the signal-chain on my B1 Buffer. And I use Allen Bradley on the Sowther Trafo on the Direct SC3248Dac.
When I removed the Nec bypassed Cap, the edgyness disappeared and my Alp12P was back to that fine state of very transparent displaying of the musical content of everything I throw at the chain - and without my ears/wife being bothered with sharp sound and music.
So my experience is opposite to you - with my chain of electronics - Dac w/trafo and Carbon Resistor - B1 Buffer w/Carbon Res - LÀmp w/Carbon Res, AND no Bypassed Source Resistor. Clear and distinct sound with no edginess, and Solid State.
But to this I will add: I think I found a good speaker to make the Alp`s sing beatiful!
Best
Olav
Old 5th July 2013, 07:28 AM   #1715
OlavHaal's Avatar
Red face Some missing words in post...
Hi all!
Some statement that was wrong in my last post - the last line should read: I think I found a really Good SpeakerCable to make the Alp12P sing beautiful with the L`Sit Amp!
And I have made the cable run straight to the driver - with no BindingPosts on the back of the speakers.
Best
Olav
Old 5th July 2013, 03:33 PM   #1716
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
What speaker cable is it?
I build, therefore I am.
Old 5th July 2013, 03:35 PM   #1717
juanitox's Avatar
hi olav, i have now a 26 DHT preamp with output cap and now use a 4V cell battery as Bias with my sitamp ... but from the time i used a bypass cap and douce resistor i didn't notice any hardness in the sounds but i was using a 47000uf mundorf mlytics in this place..
anyway you have a fantastic looking wooden case for your sitamp !!!
cheers
rohan
Old 5th July 2013, 05:29 PM   #1718
OlavHaal's Avatar
Arrow Yes Vdi_nenna and juanitox...
Hi both builders of fine audio gear....
I used the Nanotech(silver/gold layered) diy cable-kit from Jaguar-design, and it gave a very audible and warm displaying of the music when I changed from some self-made silvery/copper(also good) - bought from EBay! the silver could also sound some cold at times!
Yes Juanitox - my boxès for the SIT was nearly as ordered(they were made for 3 liter wine-box), and I fixed and strightened them somewhat so they could stand the 400 watt trafo + some electronic and such! Ended up stuffed - and I don`t want to show the inside - even if it is fairly orderly and safe - it is STUFFED. Some Heat-sink also.....
I think I will build a new pre-amp, so I have not moved the Nec-cap fully out(disconnected) - and will make a LDR - based pre-amp from Tortuga(probably) in the autumn. So I will try it again.
But the sound is again harmonius and revealing AND without the roughness that the Caps was displaying(or maybe they should have some more run-in time????)
But the sound with Carbon is my preferance on The Sowther Dac-The B1 an The L`Sit!
Best
Olav
Olav
Old 10th July 2013, 08:45 AM   #1719
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by OlavHaal View Post
Hi Juanitox!
I tried the solution with the bypassed Source resistor - where I used a 10volt/0.22 Farad Nec capacitor.........
these are "memory caps" , so - having sissy current capabilities , absolutely inadequate for task
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 10th July 2013, 04:16 PM   #1720
OlavHaal's Avatar
Thumbs up Thanks Zen Mod...
Hi!
Had afeeling for just that - not exactly Audio Capacitors. I was just curious about the sound with these as they didn`t look to far off from what other used as bypass caps.
So I keep to my straight and simple solution as my Amplifier is today:
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
