L'Amp: A simple SIT Amp - Page 169 - diyAudio
Old 3rd May 2013, 06:46 PM   #1681
Telstar is offline Telstar  Italy
Mine hasnt seen the light yet. I'll build it next month hopefully.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 3rd May 2013, 07:22 PM   #1682
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Has anyone noticed a difference in power output with bulb/resistor/CCS vs choke, relative to the same loudspeaker?
I build, therefore I am.
Old 3rd May 2013, 08:44 PM   #1683
juanitox's Avatar
Originally Posted by generg View Post
I thought I was the only one who could not decide to which version of my amps sound better......nice to have a French compagnion!
in fact with a SS preamp i prefer bypassed source resistor version and with a tube preamp with output coupling cap i can go with battery on source which i prefer to LM317 bias module.. but anyway this sit is a keeper .
potting the 193V is a cheap but fine upgrade
French is not a crime.
Old 4th May 2013, 02:22 AM   #1684
The one and only
Nelson Pass's Avatar
You bet. The choke is theoretically twice as efficient as the CCS and the
CCS is about twice as efficient as the bulb/resistor.
Depending on voltage and bias, you can get a lot of difference.
Old 9th May 2013, 02:58 PM   #1685
Default Antek transformers are back in stock
The AS-4428 is now available for the inductor version. Two 28v outputs and 15v outputs at 400VA. The PDF shows a different voltage of 6.3v instead of 15v but the tech rep reassured me that it was 15v. Here's the site
Antek - AS-4428
Old 22nd May 2013, 02:21 AM   #1686
vdi_nenna's Avatar
The L'amp part Deux schema shows a 28vac transformer.
The L'amp 193v schema shows a 18vac transformer.
Is the 193v version a misprint or does it require less power for the same output?
Thx
Vin
Old 22nd May 2013, 04:21 AM   #1687
I don't think it is a misprint. The spool has higher resistants than the 193v.
Old 22nd May 2013, 12:10 PM   #1688
flg is offline flg  United States
flg's Avatar
They both should have similar Drain quesant Voltage. The difference is in the Bulb and CCS versions, the supply gives up half it's voltage across these componants to allow full signal swing pos and neg. In the Inductor version, there is almost no Voltage across the inductor in a quiesant state. The varying current and inductive reactance of the inductor creates half the signal Voltage swing.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 22nd June 2013, 08:26 PM   #1689
KASUMI is offline KASUMI  United Kingdom
Well finally finished mine
From
To
Old 22nd June 2013, 08:52 PM   #1690
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
whoa!
what's that wood ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
